Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Am I about to make a mistake? Powering Carnetix
    Newbie PatInTheHat's Avatar
    Jun 2007
    My plan was to run an 8 guage wire with a 15 amp fuse straight from my battery to the carnetix 1900. When I received the carnetix I noticed their connector is using 16 guage wiring.
    This leads me to believe the carnetix was designed to just run off a power cable inside your car?
    What do you guys recommend? Will I have any problems running straight from battery at 8 guage and then splice the wires to the carnetix down to 16 guage?
    Or should I just find a 12V battery tap inside my car and run it that way?
    Registered User
    Quote Originally Posted by PatInTheHat View Post
    You have connect the carnetix directly to the battery, but you can always run the 8 guage wire to a distribution block.
    Jun 2006
    Chicago, IL
    I connected mine right to the radio harness, but I'm not really overloading the PS. I have minimal setup (1GHz epia, with flash drive, no hd, no cd, just the screen)
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
    Elsewhere
    I wouldn't do it. You're definitely on the right track with the 8awg cable. That might be overkill as far as the wire thickness, but it's certainly not going to hurt anything...
    Quote Originally Posted by dupa2 View Post
    While it may work for YOU, it's certainly not recommended if you want a safe installation.
    How about the Wiki?
    Jun 2007
    Alright im just going to find a way to splice the 8awg and the 16 together and continue as originally planned.
    Just to double check, is it perfectly ok to go from one guage to another? I also purchased 12 guage to run throughout my car and I noticed most cabling is 18guage+ and I will be having to make several splices.
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Yep u gonna have to find a connector to connect the two together. I myself use 8 gauge wire for my car pc. Just use a tapper to tap into the wires if you want to that what i do.
    Maximum Bitrate GoHybrid's Avatar
    Jun 2006
    Denver, CO
    i just took the 16ga and meshed it straight into the 8ga... it helps if you haven't already twisted or otherwise mangled the bare wire ends. Once they were together i just flooded the joint with solder and used heatshrink tubing around it. Worked like a charm.
    Jun 2007
    Perfect thanks guys. I may just do what you did GoHybrid, works for me.
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    I second GoHybrid's idea, thats what I did too.
    Make sure to get electrical solder from radio shack the ones they carry melt failry easy. Ohh and be sure to put soldering flux/paste on your wires prior to soldering, it will make the soldering wires together MUCH easeir.
    Jun 2007
    Here's a nice little table that has some good recomendations for vehicle wiring:
    Code:
                    Length of run (in feet)
        Current     0-4  4-7 7-10  10-13  13-16  16-19  19-22  22-28
          0-20A     14   12   12     10     10      8      8      8
         20-35A     12   10    8      8      6      6      6      4
         35-50A     10    8    8      6      6      4      4      4
         50-65A      8    8    6      4      4      4      4      2
         65-85A      6    6    4      4      2      2      2      0
        85-105A      6    6    4      2      2      2      2      0
       105-125A      4    4    4      2      2      0      0      0
       125-150A      2    2    2      2      0      0      0     00
    Generally it is not OK to splice a larger gauge to a smaller gauge without a fuse sized for the smaller gauge in between the splice, if the smaller gauge is on the load side. If the smaller gauge is on the supply side, then you want a fuse sized for the smaller gauge between the supply and the small gauge wire. Remember that fuses are there to protect your wiring from melting/burning so you always want to put a fuse in the circuit rated just below the maximum rated current of the smallest wire in the circuit.
  1. Fiberglass and MDF sub enclosure walkthrough
    By monkeyracer in forum Fabrication
    Last Post: 05-19-2008, 03:55 PM
  2. Replies: 7
    Last Post: 01-24-2007, 10:31 AM
  3. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  4. Carnetix P1900 (brand New Brought By Mistake)
    By rockyfozz in forum Classified Archive
    Last Post: 08-14-2005, 06:34 PM
  5. STUPID mistake I made - M1-ATX
    By sxt173 in forum Power Supplies
    Last Post: 02-21-2005, 12:33 AM
