Results 1 to 7 of 7
Thread: PSU selection
    Mar 2007
    PSU selection
    I was browsing and I see the OPUS or the DSATX or the M2 choices for my setup
    I will be running
    VIA EN15000G
    1GB RAM
    100GB 5400RPM SATA harddrive
    DVD-RW (possibly burning also)
    Bluetooth USB
    Wifi USB
    GPS USB
    2 usb ports on the front
    expresscard USB adapter
    and a 7" touchscreen that dual-din one here on the store
    in addition to a USB keyboard and mouse
    I was looking at these and not sure on what to get and how I would have power for both the SATA harddrive and dvd burner, unless I use a splitter. I was thinking of dropping in a kill switch if possible where if I was storing the car for a week or more, I can ust flip the switch and turn it off (if possible)
    any recommendations?
    I would reccomend getting a 2.5" Laptop hard drive, rather than the 3.5" desktops, they are more resillient in design!
    It is very easy to wire in a kill switch, when you wire the power supply in, just put a switch on the positive wire. You could if you wanted, get a oem switch from your car makers and hook it up on the dash so it looks OEM, which is what I am planning to do with mine. It does require some extra work, but worth it in the end.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by BiG K View Post
    So far, in the NUMEROUS threads on this board, there has not been any data to back this up. I've been running a full size drive for well over 3 years (never run a laptop drive) and I've never once had to replace a drive because of failure.
    Jan Bennett
    Mar 2007
    I am getting a 2.5" SATA hard drive. But what psu should I look into getting
    _
    Mar 2004
    Little Elm, Texas
    You should check the FAQ link in the nav bar, but just to be nice, I'll link you to the FAQs that you should really read:
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=2
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=3
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
    Jan Bennett
    Mar 2007
    Hmm so according to the manual of the VIA EPIA EN15000G, it takes 19watts max? doesnt sound right. I did look before at those FAQ's but still am a bit confused here and there about it.
    Yup Epia's just dont use much power, which is why us car enthusiats prefer them!
    REDGTiVR6 - While it is true, that 3.5" hard disk drives may be as resilient as a 2.5" hard drive, manufacturers claims do back it up, by listing the operational shock measured in G's. 2.5" Usually have a much higher shock tolerances. As long as you do not cross the operational shock boundary's, you'll be fine. Which in your case, your normal day to day driving doesn't cross the operational shock values.
    If your running a carpc in a small confined and hot space, power consumption really is an issue, as the more power you put into it, the more heat you get out, and all that heat has to go somewhere!!
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  2. 650W PSU blew up my dual XEON setup
    By Chris31 in forum Off Topic
    Last Post: 09-23-2006, 07:55 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
