No No No!
Only use the Acc wire in the stock harness for the sensing in an intelligent PSU. The guage is not thick enough to safely provide enough current to a PSU. Run a decent wire from the battery or fuse box for safe, clean power.
Not required. see answer 1. You can use a relay in conjuunction with the acc feed to power on a PSU through your new wire if you wish. If you don't understand what this means, please read a little one basic wiring and componenets before proceeding.
Google is your freind.
Good luck
LinkBack URL
About LinkBacks
