Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: My Diagram - Determining Wire Gauges
  1. #11
    Aug 2005
    WTH? I've read numerous times on Car Audio forums you should NOT run your ground back to the battery..
    So much BS on the internet
    EDIT: http://www.mp3car.com/vbulletin/car-...ng-my-amp.html.. All saying to ground to chassis
  2. #12
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by gokee2 View Post
    Vladcarpc:
    It would help you to help us know what sort of amplifier you are tyring to power because from there, you can easily determine your power wires, ground wires and calculate your fuse ratings in conjunction with your distribution blocks.
    HU, AMP and Sub are already installed, I will check its specs and post here.
    And yes, I agree with crooper. Dude, there is nothing wrong in trying to wire this yourself. If there is an issue, you can always made adjustments. You can do it, as long as you ask direct questions. We're all here to help Cheers
    Thanks, I think I will try to do it myself...
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
  3. #13
    Nov 2006
    Sao Paulo, Brazil
    Thumbs up Questions about drawing 1.3 (post #4)
    Hi! Thanks for your replies.
    Based on the drawing of post #4, here are some questions:
    1) What awg should I use for power and ground to the lilliput?
    2) For the lilliput I think of using a molex connector (HDD) in the PC side and solder the long wire to the Lilliput cigarrete adapter wire that I've cut, so I can use the barrel plug. Or should I solder a barrel plug directly into the new long wire? What do you think?
    3) As I posted before, I read that the fuse for the 4 awg wire is 125 amps, can I commit that?
    4) About grounding to chassis, is there a recomendation of where to attach it? I mean, can I just fix the wire into any piece of steel below the trunk carpet?
    5) Take a look at the other wires' awg that is in the drawing, can I consider them OK?
    Thanks a lot, again!
    \/ |_ /\ [)
    1995 Civic Sedan EX
  4. #14
    Jun 2007
    Alpharetta, GA
    Everything looks fine, you may want to put a fuse between the distribution block and the carpc just to be on the safe side. Don't want 125 amps shooting into your M2.
    I think the lilliput power cable uses 18 gauge wire, so that should be fine. You could go to a thicker wire just to be safe, but I would use the same gauge wire you use for the lilliput on the valet switch so that you don't have to buy extra wire. Unless you just happen to have a bunch laying around.
    Whether you solder a new barrel plug onto a new power wire is really up to you. If you are planning on using the screen in more than one vehicle, you may want to make a whole new wire so that you have two. Also if you are using a thicker wire than is used in the stock cable you may want to go ahead and solder on a new barrel plug. Oh and I would recommend putting a fuse on this line too. Screens are expensive to replace.
    Oh, and are you powering that USB hub? You may want to go ahead and run a 5v line from the molex you are getting the power for the lilliput from. You don't need it if all you are running is the keyboard, but if you wanted to add more in the future it would make it a lot easier.
    Hope that helps.
  5. #15
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Why should you use the absolute maximum fuse? That means you have to hit 125 amps before it'll blow. Putting a 60 on there will give you more protection, not less (it'll blow at a lower amperage). Besides you said yourself in the last table on that link "These are the maximum recommended fuse ratings for the corresponding wire size..." He said in his first post that he's going to use 4 awg power wires, so 60 amps would be under the 125 amp recommended fuse.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    The fuse under the hood is to protect the wire as it runs through the vehicle. You're fusing the wire, not the components at this point.
    Besides that, if he's determined that he needs to run 4 gauge wire, chances are he's going to be pullng more than 60 amps of current.
    The fuse up front shouldn't be grossly under rated for the complete system, nor should it be grossly over rated.
    This is why it's critical that we know how big his amp is and what it's fuse rating is.
    Jan Bennett
  7. #17
    Nov 2006
    Sao Paulo, Brazil
    Question AMP specs
    My Kenwood HU and AMP are already installed. Bought them in 2002.
    Kenwood KDC-X859
    - Specs I found in the web:
    - 50 watts x 4
    - 2 pairs of RCA (4,5V) + 1 pair for subwoofer
    - Some pics I found: http://www.ivox.com.br/produto/?dir=...301/6350:64955
    Audiobank Power Mosfet KA 4070
    - 4 x 100 rms 2 ohms
    - 4 x 75 rms 4 ohms
    - 2 x brigde 180 rms 4 ohms
    - Some pics I found: http://produto.mercadolivre.com.br/MLB-61184988-_JM
    I hope these specs are enough. If not, tell me and I will search for its manuals. They are already installed in the car, I didnt see the installation, but I can see that there is a fuse in the hood and that's it.
    In my diagram I used 4 awg wire just because I read many people using it. Is it overkill in my case? If there is no problem, I would prefer using the thicker wire for safety.
    Thanks!!!
    \/ |_ /\ [)
    1995 Civic Sedan EX
  8. #18
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    Hi mate. I think the 4awg wire is the correct one. as i understand you calculate your max draw, total watts. the amps are 200+400watts+160watts(m2-atx)=760watts. then amps=watts/volts=760/13.5=56.29AMPS
    From this post: http://www.mp3car.com/vbulletin/car-...-see-here.html
    see what lenght you need positive wire and you might get away with 8awg
    I would agree with RedGTiVR6 that you would'nt get better ground than wiring strait to the battery's negative.
    All amps and PSU has theyr own fuses, so the fuse you are installing is for wire.
  9. #19
    Nov 2006
    Sao Paulo, Brazil
    Thumbs up
    Quote Originally Posted by moleman View Post
    I heard of distribution block with fuses. The M2-ATX comes with a fuse built-in, so you recommend an additional fuse in the wire?
    I think the lilliput power cable uses 18 gauge (...) Oh and I would recommend putting a fuse on this line too. Screens are expensive to replace.
    Good idea. I would need to determine the fuse size for the Lilliput and the M2-ATX.
    Oh, and are you powering that USB hub? (...) it a lot easier.
    I would use it for the keyboard and pen-drive, currently not powered. But I am considering that. Good point.
    Hope that helps.
    Thank you!
    \/ |_ /\ [)
    1995 Civic Sedan EX
  10. #20
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by agniusm View Post
    In the 760watts calculation, what is the 200? 400 is the amplifier.
    I think that 4 awg is better, just for safety, but I am concerned about voltage drop and wire costs (have no idea).
    I was thinking of buying a distribution block with fuses, so there will be extra protection for each device (Lilliput, M2-ATX).
    \/ |_ /\ [)
    1995 Civic Sedan EX
  1. [CoupeE46] BMW E46 2001 330ci CarPC ...
    By CoupeE46 in forum Worklogs
    Last Post: 10-02-2008, 08:16 AM
  2. Replies: 7
    Last Post: 02-08-2007, 04:39 PM
  3. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  4. opus 150 wire gauges
    By kilomo in forum Power Supplies
    Last Post: 05-23-2005, 12:25 AM
  5. Electrical Diagram Help?
    By Optikal in forum General Hardware Discussion
    Last Post: 12-10-2004, 10:16 AM
