Results 1 to 6 of 6
Thread: Standby power
    Feb 2007
    Johannesburg South Africa
    Standby power
    I’m using an inverter with a diy startup/shutdown controller.
    It triggers the pc to hibernate.
    Can I use an external 5V power supply to power the standby pin on the motherboard while the inverter is off?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    you don't need any power when hibernating you only need to keep power there if you use standby.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Sep 2005
    Quote Originally Posted by v8 scimitar View Post
    So are you saying hibernation is a better solution to standby, if you don't want to drain your car's battery?
    Jan 2005
    Scotland
    If you don't want to drain your battery yes its the better solution. Standby is faster but uses power.
    Feb 2007
    I want to use standby. I think the 5V on pin 9 is to keep the memory powered. I also see that pin 14 is 5V when the pc is off or in standby but change to 0V when it is on.
    Can someone tell me the amount of current needed in standby.
    Elsewhere
    Quote Originally Posted by Mazda6gp View Post
    No, because it depends on the system that's in standby.
    How about the Wiki?
  1. wiring SLA battery as standby (S3) power
    By ~docfx~ in forum Power Supplies
    Last Post: 10-26-2006, 08:16 AM
  2. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  3. Usb power and Standby
    By dmcdlrn in forum General Hardware Discussion
    Last Post: 05-24-2005, 09:36 AM
  4. Aux DC-DC standby for inverter users
    By Scouse Monkey in forum Power Supplies
    Last Post: 01-13-2005, 01:04 PM
  5. standby power drain problem
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 03-08-2004, 05:12 PM
