Results 1 to 2 of 2
Thread: SPLIT: PSU Wiring
    Jul 2007
    Arkansas
    SPLIT: PSU Wiring
    Ruffy (or anyone else who might be able to answer this): where do you tap into the car's power? Perhaps a better way to phrase the question: would it be better to run a line directly to the battery (fused properly, of course), or would it be acceptable to run a single 1/0 power cable to a fused distribution block, and connect the computer and amps to that block? (with each amp and the computer having an appropriate fuse on the block).
    Elsewhere
    Quote Originally Posted by JKrepps View Post
    1 - This is a threadjack. You need to start your own thread for your unrelated issue. I've split this off to its own thread.
    2 - This is all answered in the manual for the power supply you use.
    3 - A distro block setup like you specify is acceptable.
    How about the Wiki?
  1. Dell SX260 and SX270 power supply solution
    By ivanmx6 in forum Power Supplies
    Last Post: 12-30-2008, 06:39 AM
  2. Replies: 3
    Last Post: 09-14-2006, 11:54 PM
  3. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  4. Wiring DC/DC PSU to cigarette lighter
    By ericthebikeman in forum Power Supplies
    Last Post: 07-17-2004, 07:46 AM
