Results 1 to 8 of 8
Thread: Opus 150 5V mod ?
    Apr 2007
    Opus 150 5V mod ?
    I’m trying to get a carputer together and in an effort to save a few $ I bought an opus 150 used with the 5v mod already done.
    My problem is that I just don’t get exactly how the mod was done and what I need to do to get the PS to work. I assume that the person I bought it from used the mod in this post
    http://www.mp3car.com/vbulletin/powe...r-cpu-off.html
    I’ve read though the thread several times but I’m missing something.
    I’m guessing that I need to hook the blue cable up to something but I just don’t know what. Could someone please help me and point me in the right direction.
    Here is a picture of the ATX cable if it helps
    Low Bitrate BRow86's Avatar
    Dec 2006
    MA
    I'm guessing the blue cable is ground. Where did you buy the mod from?
    CarPC: 100%
    Software: 100%
    Amps/Subs: 0% (on hold)
    Fabrication: Need help!!! Someone in Boston area who can help me with this please send me a PM.
    Apr 2007
    Quote Originally Posted by BRow86 View Post
    I got it from here
    http://www.mp3car.com/vbulletin/vbcl...p?do=ad&id=695
    I'm guessing it was done using this But i just don't know and because its power I don't want to fry my new equipment or burn down my house.
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    had to do some searchin.... havent seen this in a long while. I lost the pics for this mod, but the blue wire is not ground. if i remember right needs to be connected to the ACC wire. the same wire that turns on the opus 150. If its wired correctly, the wire turns on/off the relay that enables/diables 5vusb.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Sep 2003
    central valley
    Opus
    I built that many years ago and it has worked flawless. I have to give member "Rando" all the credit. Here is the schematics on which I built it off of. Also here is the thread. It is a couple pages deep. I am sorry I don't remember exactly where that wire went (I am getting old) but I believe the post about it is hooked up to 5 volts is correct.
    2004 Toyota 4runner
    Apr 2007
    Quote Originally Posted by calitundra View Post
    I know how that goes.
    I guess I'll try to contact OPUS and see if i can get them to update the firmware with the 5v shut down so I don't have to guess.
    If they won't/can't do it. I'll hook it up to an old computer and test it by running 12v to the blue wire and see if it works.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Given that this was pulled from a working mod, I'd say it's a 99.9% chance the blue wire is ACC since the ACC signal is the only one that MUST be pulled external from the ATX cable. Using blue for ACC is an automotive convention -- so it looks like whomever wired that up was giving themselves a visual reminder of how it should be hooked up.
    If you're not comfortable, the wiring can be confirmed with an ohm meter.
    Apr 2007
    Thanks for the reply.
    Using an AC to DC inverter I hooked it up to an old computer with the blue wire hooked to a 12v line (simulated acc line) and the power supply worked flawlessly.
    I hooked the opus up to an AC to DC inverter with the blue wire hooked to a simulated acc line. The power supply worked flawlessly. I tested the draw with an amp meter and found that the draw was tiny. I’m pretty sure it’s connected properly.
    The only thing that concerns me is that the Opus hisses pretty bad when it’s pulling more than 3-4 amps
  1. Replies: 11
    Last Post: 10-10-2005, 10:05 PM
  2. Opus 150 and negative rail problems!!
    By wallaceacura in forum Power Supplies
    Last Post: 07-23-2005, 10:20 PM
  3. Opus 150 problem (overloading rails)
    By Craig W in forum Power Supplies
    Last Post: 07-18-2005, 12:16 PM
  4. Opus 150 systems!!
    By tangeray in forum Newbie
    Last Post: 06-22-2005, 08:19 PM
  5. Opus 150
    By titaniumkingpin in forum Power Supplies
    Last Post: 02-17-2005, 03:23 AM
