Results 1 to 10 of 12
Thread: Power supplies, some basic questions
    Aug 2007
    Hi i am looking at putting a sx260 in my car and have been reading up on a variety of ways to power it. Some use a requlator and some use a PSU can some one tell me the difference between these and when would you use one over the other.
    Rich
    Aug 2007
    Anyone??
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    I do not know what an sx260 is but generally speaking a regulator regulates a higher voltage to a stable output. Example 15v to 12v.
    A psu ( I think you mean a DC-DC ) can deliver a stable output over a range of voltages. Example 9-15v to 12v. This is important in a car since the battery can run as low as 9 v during starting and the alternator will supply 13-14 volts while driving.
    Elsewhere
    A regulator does just what the name implies: It regulates the 12v power from your car's electrical system (which fluctuates during normal operation).
    A PSU is more what you'd use when building a desktop. It's ATX compliant and connects the same way.
    Other people may have different definitions, mind you. That's how I view it.
    How about the Wiki?
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    I'm also not sure what an sx260 is. But, there is a wealth of information on this topic both in the forums, and in the mp3car.com wiki.
    Probably all the information you'll ever need is right here.
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    I'm guessing he is referring to a Dell Optiplex Sx260
    I believe they use power bricks like laptops.
    Apr 2005
    Southern Califorina
    Quote Originally Posted by Phatsacks View Post
    Ahhh... That would make sense.
    In that case that link isn't of much use.
    He'll need a DC-DC Power Supply which takes 9-18ish volts, and always outputs the voltage required by the laptop, and with enough amperage to keep it going.
    I had a laptop I wanted to run in a car that actually required 19v at some ridiculous amperage. Most laptops are 12v or below though, so it should be reasonable to find an appropriate power supply.
    Check out my blog.
    Apr 2005
    Southern Califorina
    Check out my blog.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by cherrybomb View Post
    A bit OT, but did that happen to be an Acer? I could never find anything to power that beast. Even the sockets under the seats in an airplane wouldnt give out enough power for me to charge it when on. It would charge if turned off, and would just flicker the screen rapidly if turned on and plugged in...
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    Sorry, yes i meant a Dell sx260, anyway thanks for your input guys, i think i'll go for a psu, probably the DSX12VD, one other question, the psu in question has a motherboard connector as the output (obviously to plug into the motherboard) (molex i think...), however as someone has mentioned, the sx260 has a external power supply and i will need to use the connector end to plug into the pc, can i just cut off the mboard connector and splice it into the psu cable?
  1. FS: Dc-Dc Power Supplies, IR Keyboard/Mouse, PS2 Extension
    By Rundell in forum Classified Archive
    Last Post: 03-13-2005, 03:20 PM
  2. Replies: 12
    Last Post: 11-16-2004, 09:44 PM
  3. key power power supplies
    By Sway in forum Power Supplies
    Last Post: 04-03-2004, 10:26 PM
  4. dc-dc 250 watt power supplies
    By dscustoms in forum Classified Archive
    Last Post: 05-30-2002, 02:05 AM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
