Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: DS-ATX - Red LED, but no power
  1. #11
    May 2005
    San Clemente, CA
    Thanks for the diagram! I went to RadioShack and picked up the correct parts for the relay. The P/Ns for the RadioShack resistors are for the same 10k 1/4w resistors I used in my original switch, so I just reused them. Soldered it all up and... same problem.
    Guess I will give the relay method a shot, because I already have one I can use.
    Edit: I tried the relay and you will never guess what happened... yeah same thing! Is this a timing issue?
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
  2. #12
    Apr 2001
    Portland OR
    Quote Originally Posted by WiCKeD 5.9L View Post
    Have you played with the settings in the bios? What is it set to do after "Power Fail"?
    Can you take a movie and post a video of whats happening?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  3. #13
    May 2005
    San Clemente, CA
    Bios is set to "Former-Status"
    Movie?? I don't know what that will show.
    Here is a quick summary:
    1. Turn key on accessory position
    2. 5 seconds later the fan begins to spin, PC and LCD turn on.
    3. 5 seconds after this, the PC shuts down, before the BIOS post screen is displayed.
    Alternate:
    2. 5 seconds later, the fan begins to spin, PC and LCD turn on.
    3. Immediately remove the power switch from the motherboard header
    4. PC boots normally
    I can shut the PC down by plugging the switch back into the board.
  4. #14
    Apr 2001
    Portland OR
    Alternate:
    When you have the relay power switch method hooked up. Can you hear the relay click twice or is it just clicking once for the first startup?
    Try setting the BIOS to "Stay Off" and see what that does.
    www.mpegbox.com
  1. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  2. How to Power an Infill G4 Unit using an ATX PSU
    By snakeye5 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-20-2007, 07:52 PM
  3. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  4. Power led on xenarc - necessary?
    By Barren in forum LCD/Display
    Last Post: 08-12-2005, 12:34 AM
  5. blinking power LED
    By tunnel vision in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:45 AM
