Results 1 to 10 of 14
Thread: DS-ATX - Red LED, but no power
    May 2005
    San Clemente, CA
    Just installed the DS-ATX into my car and the only activity I am getting from it is the red LED. Using the same wiring configuration I used for an M1-ATX, M2-ATX and Opus 150w, so it should be working...
    I have flipped the power connector on the DS-ATX and motherboard (all 4 combinations). ACC is soldered from the fuse for the [insert something that turns on with the car] straight to the ACC input on the DS-ATX and the amp turn-on also connects to this. Amps turn on when car is put in accessory position and DS-ATX red LED turns on. Amps and DS-ATX stay on when I take the key out of the ignition. I have to pull the battery to turn everything off.
    Motherboard is the MSI 945GM2 Fuzzy, which has no P4 connector. PC was just working with the Opus 150w and connected to an AC PSU. I switched to the DS-ATX, because I wanted something smaller that would fit in my case.
    Any ideas?
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Apr 2001
    Portland OR
    Quote Originally Posted by WiCKeD 5.9L View Post
    I have flipped the power connector on the DS-ATX and motherboard (all 4 combinations). ACC is soldered to the fuse for the windshield wires, straight to the ACC input on the DS-ATX and the amp turn-on also connects to this. Amps turn on when car is put in accessory position and DS-ATX red LED turns on. Amps and DS-ATX stay on when I take the key out of the ignition. I have to pull the battery to turn everything off.
    Any ideas?
    Can you draw a diagram? Is the LED flashing as the amps are staying on?
    Sounds like it's in the countdown mode..
    But if your amp turn on is from the acc and not the DSATX, how could the DSATX cause your amps to stay on?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    May 2005
    San Clemente, CA
    DS-ATX LED is solid red. The ACC line is nothing more than a pass-through to the amps. The DS-ATX is not controlling them.
    My main concern is why the PC is not turning on. According to the manual "LED ON = Running Mode" so it should be working.
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    Have you tried making the inverted polarity switch cable?
    Try momentarily shorting the power button pins on your mobo, and see if it powers up. If it does, it's just not getting the signal from the psu.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    May 2005
    San Clemente, CA
    Would I need to if this motherboard already works on other PSUs? I also tried connecting the case power switch and turning it on manually, but no joy.
    Apr 2001
    Portland OR
    On the DSATX the LED means the DSATX is capable of providing power to the computer. It doesn't mean the computer is on. The computer has to be turned on either by the jumper to the power switch or via manual switch.
    If the LED is off, there is no way the computer could come on. It's the state of the DSATX not the computer.
    www.mpegbox.com
    May 2005
    San Clemente, CA
    zoot I understand that. I just don't understand why it's not sending the signal to the board. Either I am doing something wrong or it's bad.
    I will try your reverse polarity switch mod and see if that helps. Went to Fry's to grab the parts, but did not notice it was just the part codes. Woops!
    Apr 2001
    Portland OR
    If you get a volt meter you can see pretty quick using a regular psu if the swtich polarity is the issue.
    www.mpegbox.com
    May 2005
    San Clemente, CA
    Well I confirmed the PSU works and partially resolved the issue...
    I created a reverse polarity switch with 2 x 10k 1/4w resistors and an 80V 500mA PNP transistor. Jeff's switch calls for 2 x 10k 1.8w resistors and a 40V 250mA PNP transistor. Unfortunately this was the best I could find at Fry's. I know nothing about electronics, but this seemed the closest...
    Now the PC turns on for 5 seconds and then switches off! It turns on and stays on if I unplug the switch immediately after it powers on. I tried this trick with a different standard polarity switch and confirmed it requires the reverse polarity switch to work.
    So the question is, is this happening because I am using the wrong components for the reverse polarity switch or because of a problem with the delays on the DS-ATX?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    yes it is.. I wired up a relay instead of all those components for my mobo ... I will try to make a diagram and post it here to help you...
    EDIT: I did a google search and found this on the DSATX website:
    look at the bottom half of that drawing.. that exactly what I did with just a standard 30A automotive relay..(I had a couple laying around)
  1. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 07:25 PM
  2. How to Power an Infill G4 Unit using an ATX PSU
    By snakeye5 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-20-2007, 06:52 PM
  3. Replies: 8
    Last Post: 08-22-2005, 11:43 PM
  4. Power led on xenarc - necessary?
    By Barren in forum LCD/Display
    Last Post: 08-11-2005, 11:34 PM
  5. blinking power LED
    By tunnel vision in forum General Hardware Discussion
    Last Post: 09-21-2004, 12:45 AM
