Results 1 to 10 of 14
Thread: DSATX starts fans then dies.
    Aug 2006
    Hey, i just hooked everything up. turned on the ignition the mobo LED went on, the fans started spinning (NO MOBO BEEP or POST and my screen isnt hooked up yet) after about 5 seconds everything shuts off, however the DSATX is still running (LED glowing red), when i turn the key off and take it out the DSATX led turns off. Blinks twice.
    im running an AMD Sempron 2GHz, 1CD and 1HDD..
    what could be wrong?
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Warrensburg, MO
    Is the DS-ATX (or your mobo) new to your system, or was it working and this is a new problem?
    I would check the mobo power-switch polarity.
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
    Aug 2006
    everything is brand new and never been used before. i've triple checked the mobo power-switch polarity and its fine.
    it turns on for a few seconds and automatically shuts off, no beeps no nothing..
    is there a way to know if something is fried or not..or am i gonna have to hook the mobo up to a AC-DC PSU and see if that works??
    P.S.: mobo uses 24pin, DSATX has 20pins..ive read that 20-24 converter cables dont really do much and every 24pin is compatible with a 20pin. can that be the problem?? my 4pin is connected to give the CPU power.
    thanks.
    Apr 2001
    Portland OR
    Quote Originally Posted by MastaShake View Post
    thanks.
    What happens if you remove the jumper between the mobo and JP1? Does it still turn off?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Aug 2006
    Quote Originally Posted by zootjeff View Post
    im sorry i dont quite understand, i connected the power switch between the mobo and PSU to G1,G2 (1st row) triple checked the polarity. I didnt set any jumpers on the rest of JP1 its all clear.
    in the quick installation steps there are also these.
    1) Set P1 to set the time before shutdown. Adjustable between 0-20 minutes by default in Basic Mode.
    2) Set P2 jumper to set the low voltage cutout voltage. To minimize this feature, set it to 10 volts (fully
    counter clockwise). P2 is adjustable between 10-12 volts.
    Do i need to do this..because I skipped these 2 steps all together...
    just to clarify, the PSU doesnt turn off. the mobo turns off..but the PSU doesnt. Also when the mobo first turns on, it startles a little..for instance the case fans begin to spin up and then the CPU fan..im sure thats fine and has nothing to do with this problem
    any help would be appreciated.
    Also i am running a 10gauge (10ft) wire fused with 30amps to the VIN, and the same from GRND to negative terminal.
    May 2007
    Wichita, KS
    My motherboard turns on for a second the first time i give the dsatx power too.
    You really shouldnt have to mess with p1 and p2 to get it working. But set p1 to max time and p2 to full counter clockwise for now.
    Try reversing the small 2 pin power button plug on your motherboard (that comes from the dsatx), they are mislabeled sometimes.
    Aug 2006
    thanks, but i think i got the power switch correctly. because it wasnt powering up at all before, but now it is..ill check again and try it (ill reverse again and see if that works)
    i really didnt want to mess with P1 or P2 but i guess ill have to.
    ill set P1 to max time and P2 to 10V (full counter clockwise i believe)??
    I'll also check my circuit with a voltmeter and report back here.
    any other suggestions??
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok here are a few tips..
    1. does your mobo has a 4Pin power in adition to the 24pins?? did you hook it up
    if No 1 is OK then
    2. your mobo might be using an inverted power-up logic..check Jeff's pages for info on how to make a cable for thos mobo's
    Aug 2006
    yes the 4PIN is connected.
    if i connect the case to the power switch and then just use the case to power it up, that should solve the issue temporarily? (issue of inverted power-up)..
    Apr 2006
    Greece
    yes i guess so
    that also happens if the supply voltage is below te setting (set by P2) it happened to me also when i was testing my carpc using an old desktop PSU which was supplying 11volts instead of 12..
    you should really hook up a screen to see if it is posting..
  1. DSATX firmware bug?
    By zenfe in forum Power Supplies
    Last Post: 10-04-2008, 04:56 PM
  2. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  3. battery dies eventhough I have a DSATX
    By pimpmode in forum Power Supplies
    Last Post: 12-29-2006, 08:10 PM
  4. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  5. How quiet should fans be?
    By d_sellers1 in forum General MP3Car Discussion
    Last Post: 05-08-2005, 08:33 PM
