Results 1 to 10 of 10
Thread: HELP with sproggy 2.8
    Low Bitrate backpack09's Avatar
    Jul 2002
    Plainville, Massachusetts
    ok, my 2.8 sproggy still is not working. i tried jumping over the n4007s. and still no go. arrrgh, well i took a few pics, please check to i connected everything correctly, im a civil engineer, not electrical.....
    help!!! please!!!
    TIA
    dan
    Jul 2002
    2
    Jul 2002
    3
    Jul 2002
    4
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    According to fig. dsc00013.jpg,
    It looks like you connected the 2 diodes (1N4002 - next to the relay) the wrong way. Their cathodes - the side where the stripes are- should be connected together:
    ===>|--0--|<===
    May 2002
    Malaysia/Great Britain
    ===>|--0--|<===
    I think he's right....i took a look at my own sproggy and confirmed that. So try that and then tell us if it still doesnt work
    Sproggy Mk2.8 & shutdown controller
    Via C3 800 mini-Itx 256mb Ram, 15G notebook HDD
    Life is like a Proton. You never know what you will get, but sooner or later, something will go wrong coz its a Proton!
    Jul 2002
    lol, cant believe i did that.
    well after reversing all of the n4007's it will turn on, only if i ground the pin14 lead. is this supposed to happen?
    thank you all for all the help.
    dan
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    sounds about right - the 2.8 supports the full ATX standard so that you can have a mobo-based power switch. 2.6's still powered on manually.
    Jul 2002
    Test Results...
    spec || showed
    +12V || -.835V \
    -5V || +200mV -|-------BAD
    -12V || +.816V /
    +5V || +5.020V __\____GOOD
    +3.3V || +3.303V /
    Any tips?? this is with pin 14 grounded, and all of the n4007's in the correct direction.
    do you need more pics?
    catch me on aim as backpack09
    thanks,
    dan
    Jul 2002
    wohooo i fixed it, maybe next time i should fix all the cathodes, not just half. lol
    dan
