Results 1 to 6 of 6
Thread: Desktop plugpack for Carpc
    Nov 2005
    Hey,
    I have a Via M10K MB with m2-atx psu 512 ram, 40gb laptop hdd.
    I want to make a socket on the side of the case so i can just plug a power pack and power it up from mains. This is to be used as testing but also so the carpc can be used as a normal pc (yes i'm aware of the limited cpu power)
    How large a powerpack will i need? since its 160w's it appears i need a 12v 13Amp power supply but that seems rather large. I know i can power my setup from a 12v 7amp battary (including screen) but whats the min i can get away with do the system alone?
    is ther a site i can just enter the via MB, the ram, hdd and it tells how much watts i would use max and from that i can work out min speced powerpack i need?
    thx
    tb
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Best to measure the load with a meter. Most are rated at 10Amps so have a spare fuse, though I doubt the setup is pulling more than that. For example, My home pc has a 300 watt supply , p4 , tv tuner card , dvd drive and I cannot get it to draw more than 100 watts.
    If you do add a psu ( I am considering the same ) you could get away with a battery charger from an auto parts store. I've tried this on the garage floor and it worked well though kind of ugly. This kind of charger could be permanently installed somewhere with adequate ventilation. BTW I could not get it to work with out a battery in the circuit.
    One supply I really like here..
    http://www.mpja.com/prodinfo.asp?number=16780+PS
    would do nicely if I go back to a dual battery.
    _
    Mar 2004
    Little Elm, Texas
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=4
    Might help some in this instance.
    Jan Bennett
    Nov 2005
    cheers billme, At the moment i'm designing my capc to be fully useable externally as weill as inthe car. This is simply cause if i'm making a carpc i dont want it to be limited to any single application. If your home pc is only drawing 100w then i'm sure mine wont come anywhere near that even with screen and all running.
    your link is still a too big for what i was after though.
    RedgtiVR6, at the moment i'm running/testing it via a ATX PSU, but its far from an elagant solution.
    found this which is exactly what i'm after
    http://www.logicsupply.com/products/pw12_9a
    small, light and very neat all thats needed is to add a compatiable socket in the carpc case.
    cheers
    TB
    Dec 2006
    El Paso, TX
    Yeah, I though about buying one of those $100+ 12v power supplies to power my carputer for testing, but there's a cheaper solution. I went to the Goodwill and bought an old PC with a 200 watt AT power supply. It was missing most of the parts, so I talked them down to $5. Then you just have to look up the pinouts for the AT power supply and make yourself a $5 power supply that's more powerful than the $100 ready made one.
    Nov 2005
    yeah i'm trying to find a product like the link i gace in australia.
    an AT/ATX PSU will work, but its a bulky thing to carry, idea was to have this additional PSU stored inthe car as well.
  1. Replies: 0
    Last Post: 04-20-2005, 03:38 AM
  2. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  3. Replies: 2
    Last Post: 07-10-2004, 08:58 AM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
