Results 1 to 10 of 11
Thread: Powering LS-371 ??
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Powering LS-371 ??
    Hello all,
    I am building an in-dash PC using this board:
    Commell LS-371
    It takes "8 ~ 24 V full range DC input" but probably operates best at 12V.
    I am very familiar with PC hardware but not with a car's electrical system. What exactly would I need to power this board + Solid State Disk + CD + Core2 + fan,etc.
    I was thinking of the M2-ATX HV because of high load and features. Is this overkill?
    Thanks in advance
    Elsewhere
    The M2ATX is ATX compliant and that board isn't an ATX-compliant board....
    How about the Wiki?
    Oct 2003
    Copenhagen, Denmark
    You don't need a DC-DC psu for this board, i have the LV-677DC which also has the 8-21vdc regulator, and i am running a HQCT, harddrive, 2 usb hubs and a wimax modem of the internal 5/12V connector on the board, this should also be there on yours. Look at page 37 in the manual. For controlling shutdown/startup i use a mpegbox uSDC20, which runs just fine.
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    Oct 2003
    Copenhagen, Denmark
    Oh, and i forgot to mention the board is powered directly from the uSDC20 which doesn't regulate the cars voltage, and it also survives cranking, just give at a good size wiring, and good grounding and you should be just fine.
    Mar 2007
    Socal
    Thanks for the advice!
    I will probably go with the mpegbox uSDC20 then. Is there a way to power this outside of the car for buildup/testing?
    Do you think the LV-667 is a better choice? I can choose either...
    Do you see any advantage to going with DC version over the ATX connector version of the LV-667? Won't the ATX PSU's give more features/better regulation?
    Also, do you put your PC into shutdown when the car is turned off? What about 5V standby power draw?
    Sorry, I am only familiar with standard style PSUs...it is hard to sort through so much info on this site.
    Oct 2003
    Copenhagen, Denmark
    You can power it with a regular ac/dc adapter in the 12-19V range, just remember to get one with some juice, my old 60W psu that came with my morex case works, but gets pretty hot :-(
    I think the LV677-DC saves you a lot of trouble, of course if you need to power more than the built-in regulator it can be a problem and you will need another psu, but as i said i power a 3.5" hdd, hqct radio module, 2 x 7port usb 2.0 hubs and a Wimax wireless box on that, so to me it is all i need. I use hibernate, and the clever thing is that the uSDC will cut of the power to the pc with a relay after it detects that the pc has been shut down (it measures 12v out of the pc), which means no dead batteries and such. I also have it set for around 10min delay before it shuts down, so i can get gas and go do some quick shopping before it has hibernated.
    Mar 2007
    Socal
    Do you have a screen? Do you power it off of the uSDC20 or the commell?
    I am trying to figure out how to power my screen...
    Oct 2003
    Copenhagen, Denmark
    I power 2 x 8" lilliputs off the commell 12V, the uSDC doesn't regulate anything, don't put anything that only accepts 12V directly on the uSDC.
    Mar 2007
    Socal
    Ah, I see. No regulator on it.
    So the Commell has a 12V output similar to a molex that can power peripherals. I am assuming you power your HD off of this too. Does it have the full range of Molex pins with the different voltages?
    I found out about a problem with the LS-371 and dimilar 3.5" boards that accept Core 2 Duos. There is only one memory slot onboard and the Core 2's use dual channel memory. So essentially your Core2 will act as a single core because only one memory pipeline. And intel has officially discontinued everything but dual cores and above. I was recommended to use the T5500 for cost/performance ratio.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Oct 2003
    Copenhagen, Denmark
    yes, it has +5V and +12 and Ground, all that is needed for hdd/dvd/usb hubs/monitors and so on
  1. Noob question about powering speakers
    By mozee in forum Car Audio
    Last Post: 04-16-2007, 11:24 PM
  2. Powering 7" touchscreen without SDC
    By ironic in forum Power Supplies
    Last Post: 12-16-2005, 08:24 AM
  3. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  4. LS 2.0 and Britelife combo
    By -zip- in forum FrodoPlayer
    Last Post: 04-21-2005, 09:57 PM
  5. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 04:19 AM
