Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Automatic Standby with Ignition
  1. #11
    Feb 2007
    Johannesburg South Africa
    The circuit work. I am currently using it.
    I use an inverter to the standard computer power supply.
    I use a relay to keep the inverter on until the computer switch off. This relay gets powered from the computer power supply.
    I use a second relay to switch between the main battery and the tank battery when I start the car. This relay gets powered from the wire going to the starter.
    I am using a 2A diode between the main and tank battery.
    Make sure that the tank battery is fully charged
  2. #12
    Jul 2006
    Thank you very much...ur very kind...I would request you to take the trouble of kindly giving schamatics of the crank proofing circuit with specs of relays and battery used...I have a 12V 7.5Ah battery
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
    300W DC to AC Inverter
    ::FRONTEND:: I need suggestions please
    ::OPERATING SYSTEM:: TinyXP
  3. #13
    Feb 2007
    Search for this subject
    Tank Circuit FAQ - Computers and Power cutting out
    and use this link
    Battery based tank circuit (tested)
  1. DSATX and Standby
    By HyperZulu in forum Power Supplies
    Last Post: 06-14-2007, 05:33 PM
  2. Standby issue - goes into standby and comes right back out
    By ckny in forum General MP3Car Discussion
    Last Post: 03-25-2007, 08:10 PM
  3. XP-Mini Automatic Standby and WakeUp Help
    By stevemahon in forum StreetDeck
    Last Post: 01-26-2007, 10:11 AM
  4. Opus 150 -Ignition failed
    By PORTUGAL in forum Power Supplies
    Last Post: 08-29-2005, 12:03 PM
  5. Standby issues. Seriously confused here.
    By maxxell in forum General Hardware Discussion
    Last Post: 04-16-2005, 02:26 AM
