Results 1 to 10 of 13
Thread: Automatic Standby with Ignition
    Feb 2007
    Johannesburg South Africa
    I control the pc to hibernate with the com port (rely), UPS function and the Ignition (ICC).
    How will I go about to do the same but only put the pc in standby.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Mazda6gp View Post
    WHat ever you set to make it hibernate, change it to standby. That MIGHT be set in control panel>power options>advanced.
    Michael
    Feb 2007
    I only have Hibernate and Shutdown, e.g. I don't have standby as an option.
    Is there a way to insert this option or anther program that can do this in XP?
    Elsewhere
    The ability for the PC to standy and/or hibernate is a function of the BIOS.
    So...
    You would need to set up the option to standby in your BIOS setup.
    Unfortunately, this also means that you will have to reinstall WInXP to load whatever components are required for standby, as WinXP only loads these upon installation, as far as I know.
    How about the Wiki?
    Feb 2007
    I can enter standby when I set it up to go in standby with the power button.
    I can build a controler to hit the power button on Icc on and off, but I first want to know if I can do it with software.
    Jul 2006
    anyone who figures this out - schamatics please!
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
    300W DC to AC Inverter
    ::FRONTEND:: I need suggestions please
    ::OPERATING SYSTEM:: TinyXP
    Feb 2007
    This is the controller I use. There is a delay on and off when switching the Ignition. The second part pulse the computer's on / off switch for about a second.
    Jul 2006
    thanks...
    please give part list also
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
    Feb 2007
    2 x relays look at the relay contacts
    2 x 1000uF caps they operate the second relay
    1 x 10 k resistor
    1 x 100uF cap
    1 x BC107 NPN transistor
    The switch is the ignition (ICC)
    My way of putting the computer in standby.
    I use a 7805 regulator to keep 5 volt on the memory when I put the computer in standby mode.(on the power plug)
    I use anther relay to switch the inverter off once the computer is in standby mode.
    Jul 2006
    Arrow
    Have u actually implemented this circuit - and is it working for certain. Kindly confirm.
    Also considering u have knowledge on circuitry - kindly let me know the spec's of a DIODE that I should use for a TankCircuit. the ones mentioned on the forum are not available.
    I am using the following setup:
    DC to AC inverter - SMPS powering the Computer
    now when i crank the car the inverter goes through a power surge and the Carputer reboots!
    ::CONFIG::
    Pentium 3 @ 950Mhz
    Intel 815 MOBO
    256MB RAM
    80GB HardDrive
    DVDROM
    ATI Radeon 9200
    ATI Remote Wonder
    235 ATX SMPS
    500VA UPS
  1. DSATX and Standby
    By HyperZulu in forum Power Supplies
    Last Post: 06-14-2007, 05:33 PM
  2. Standby issue - goes into standby and comes right back out
    By ckny in forum General MP3Car Discussion
    Last Post: 03-25-2007, 08:10 PM
  3. XP-Mini Automatic Standby and WakeUp Help
    By stevemahon in forum StreetDeck
    Last Post: 01-26-2007, 10:11 AM
  4. Opus 150 -Ignition failed
    By PORTUGAL in forum Power Supplies
    Last Post: 08-29-2005, 12:03 PM
  5. Standby issues. Seriously confused here.
    By maxxell in forum General Hardware Discussion
    Last Post: 04-16-2005, 02:26 AM
