Here are a few things that come to mind.
The OPUS specs claim it will automatically shut down before the battery is discharged. According the specs on the web there are jumper settings for the voltage at which it shuts down. Have you checked the jumper selection to make sure its not too low? (Of course if you're running a bunch of other stuff off the battery, the OPUS shutting down may not save you there unless its all controlled some way.)
There are various
other devices available that claim to disconnect loads from the battery if the voltage gets too low that might work for disconnecting everything.
There are fancy battery monitors used in the boating world that can monitor the charge remaining in a battery or bank of batteries. None of these are low cost that I'm aware of.
You may not need any of the things mentioned above if you provide external
power which seems like what you really need in this case.
You may be able to just put a battery charger on with enough current capacity to run your electronics with the engine off. You can spend a little or a whole lot on a charger. I can't recommend any brand.
Another option is a stand-alone DC power supply that puts out 13.8V nominally. They are used by CB and Amateur
radio operators to run radio transceivers off AC power. With one of these, you'd disconnect your battery and connect the power supply to your power bus and you can then test as long as you like without draining the battery. I'm not endorsing any of these as some have better reputations then others, but Workman, MFJ, Pyramid, Astron, Radio Shack are a few names I know of. If you want opinions, check out the power supply reviews at eham.net.
I'd still want to know if the OPUS is working correctly and if you've got the jumper selections you need because you don't want to get stranded somewhere because of a discharged battery in some other circumstance.
