Results 1 to 4 of 4
Thread: Powering a USB hub - an idea
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    Can anyone tell me if this would work:
    I run a USB hub using a cable like this:
    [media]http://www.dd-wrt.com/wiki/images/0/01/USB_dual_power_cable.jpg[/media]
    One usb plug going to the PC, the other going to this:
    http://www.amazon.co.uk/Gamers-Choic.../dp/B000LK74MG
    Would this work in providing the additional power needed to run an external DVD drive and external HDD?
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
    Elsewhere
    The USB is only going to draw enough power for a single USB port. If the devices on the USB hub draw more than would be allocated for a single USB port, then it's not going to work.
    How about the Wiki?
    Oct 2005
    Bedford, UK
    I see, thanks. Is it safe to use that cable on the DVD drive only then? Does the device only draw the required power, rather than it being pushed (potentially too much causing damage)
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    Elsewhere
    I'd think it would, but I have no way of knowing for certain.
    How about the Wiki?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 03:30 PM
  3. Replies: 5
    Last Post: 10-02-2006, 01:40 AM
  4. Is DC powered USB hub good idea?
    By civic5zigen in forum Power Supplies
    Last Post: 10-21-2005, 06:29 PM
  5. usb hub power problem
    By modUlarBeing in forum Power Supplies
    Last Post: 11-21-2004, 07:34 PM
