Hi this is my first post here.
I am puttng a camera/DVR and a lcd in my car and have a few things to work out for the
power supply which I am designing myself. For the recorder I am using a sumvision zengo/250gb hdd. LCD screen is from a sony psone using composite.
Firstly it will use about 30W when everything is switched on, though more like 10-20w most of the time. Id like to leave this on 24/7 so obviously I will need a bigger battery - the one I have now is 25A/H and only lasts 3 hours when
radio is on/engine off.
Here is my plan so far:
Get another 50-75A/h battery (one big or several in
parallel), possibly from the breakers or anywhere cheap.
I need 12v/2A and 2A/5v for the recoder including hdd.
12v/0.5A for the camer
7.5v/1A for the screen.
I would like to use switching regulators to do this but I have not used them before. Any ideas where to start?
If I used linear regulators, then I would have atleast 19.5W of waste, whilst the battery is off. This is a bit too much since Id like to run this 24hours.
12v is also a problem. Whilst there is little wasted when the engine is off, I will have problems if the battery drops low, and also the only low dropout linear ones I can find have a 1A limit.
And for 7.5v I am using a LM317T with a few extra protection components. This will only power the LCD which I doubt will ever be used for short times and not whilst the engine is running (maybe for parking if i get a second camera)
thanks
