any ideas...i dont know how to troubleshoot this..it just doesnt want to turn on at all anymore.
is it time to get a new one? lol
went to go connect my DSATX today....isolated...and nada.
no red light..nada.
what could be the problem? i dont have anything else connected to it, just GND,VIN,ACC. this should make the LED red.
i used a voltmeter and i checked the terminals. VIN gets 12V, ACC is hot gets 12V..everything is fine..so..
cant get to the fuse...because it is so *****ing tight in there in between the terminals.....
can you visually see the fuse to make sure its not blown? Rest assured youre problem will be taken care of. Jeff is a great guy and as the creator of the DSATX he may have a solution for you.
Live mp3Car Facebook Chat
you have to check the fuse.. it sounds like its the culprit...
use some needle nose pliers and be careful
nope..thats what i was gunning for.
the night before last night, i isolated my DSATX and ran it..everything was perfect, the PC was steady. however my DSATX was not mounted to anything, so obviously i cannot drive like that.
so last night i got a piece of plastic and mounted the DSATX onto it. I rested the DSATX on static foam and mounted it to the plastic..the screws i have are kinda short, so there wasnt any space between plastic,foam, and DSATX. everything was tightly on top of each other(which is probably not a good idea).
then I mounted the whole plastic piece to inside of the PC case.
I connected all the wires (GND,VIN,ACC) . Went to turn my ignition on and nothing. No red LED even. So I figured I did something wrong once again.
I decided to isolate my DSATX just like i did the night before. I disconnected the 24pin and the 4 pin and the pwr switch. And had the DSATX only connected to GND,VIN, and ACC. Not laying on anything. I turned the ignition and once again no red LED. I got out my voltmeter and checked the terminals and they are all getting proper reading. So I was getting 12V and still nothing.
Hence I am confused as to what could be the problem. I did not do anything between the night before and last night, except mount the DSATX to the plastic. Maybe during this part i somehow damaged something..i am not sure.
I will check the fuse tonight, but im pretty sure its not the fuse...i dont know why it would be under these circumstances.
Ouch. If your talking about the pink foam they ship electronics in....... that conducts electricity
http://en.wikipedia.org/wiki/Antistatic_bag
the resistance of the pink foam is too high for you to worry about it.. I run my DSATX on top of the pink foam with NO problems
thats what i figured as well, i dont see it as a problem...however maybe my DSATX was too tightly on top of the foam that caused it some problem?
Before you starting to pull your hair out (if any left), check the fuse.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
