Results 1 to 2 of 2
Thread: Any DC-DC psus support ATX 2.2/24-pin ATX
    Aug 2007
    New Orleans, LA
    Greetings all. I just bought a Biostar NF61S Micro. So far, it's looking like a bad-*ss motherboard with a nice Sempron mobile 3000+ on it. However, I have been having problems with it where when I go to shut it down, the instant it's supposed to turn off, it restarts instead. I'm using an older 20 pin psu. I hooked the mobo up to my 24 pin ATX 2.2 powr supply in my main computer, and it seems to shut down perfectly. So, I am concluding that it needs the additional 4 pins to maintain proper shutdown operation (?). Do any of the DC-DC power supplies support the 24 pin connector? Or, if none do, does anyone know what kind of additional load on the power supply this would cause if I used a 20 to 24 pin adapter? I'm not using the PCIe slot, which is what I thought the extra 4 pins were for, but I'm guessing Biostar tapped off of it for something. This mobo also needs the P4 connector.
    Elsewhere
    There are 20-pin to 24-pin adapters available.
    How about the Wiki?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Tech Support Calls
    By Rafster in forum Off Topic
    Last Post: 06-12-2006, 12:49 PM
  3. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
  4. AT and ATX pin assignments
    By drew in forum General Hardware Discussion
    Last Post: 11-22-1999, 09:47 PM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 08:47 PM
