Results 1 to 8 of 8
Thread: Fuse
    Aug 2007
    Texas
    Fuse
    What size fuse should I use between my battery and dc power supply?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    depends...
    What power supply will you be using? Look in the manual for it to determine the amperage needed. That will also be a consideration as to what size wire to run.
    See the FAQ's, specifically this one:
    http://www.mp3car.com/vbulletin/advf...iew&advfaqid=5
    ~Jimmy
    Aug 2007
    Texas
    I am using a OPUS 250W/320W Intelligent DC-DC PSU, but nowhere in the supplied literature does it state the amperage.
    Mar 2006
    Colorado, but Canadian!
    P = V x I
    [Watts] = [Volts] x [Amps]
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    Texas
    Thanks for all the input. The answer I came up with was 15 amp. Does that sound correct?
    Mar 2006
    250W is 20A and 320W is 27A. You dont have a 250W/320W you have one or the other.
    And usually you take 115% of the value.
    Aug 2007
    Texas
    how do I know which wattage it is, because the description says both?
    Mar 2006
    Quote Originally Posted by jasonobrown View Post
    The description is for both. But when you order, there is a dropdown for the 320W for additional money. Obviously you dont pay the same price for more wattage. You should know what you buy.
  1. Replies: 21
    Last Post: 11-13-2006, 07:35 AM
  2. low amp fuse blowing in MX radio adaptor
    By march09 in forum Car Audio
    Last Post: 01-06-2006, 06:53 PM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
