Results 1 to 10 of 12
Thread: M2-ATX is there final solution?
    Nov 2005
    I have M2-ATX and EPIA SP13000, everything build in VOOM2 case. I read many threads and much more posts about problems with M2-ATX. I did not find the final solution for my problem, but I'm tired with browsing all these information so sorry if my question has already somewhere deep in this forum resources answer.
    I would appreciate any help. My problem is as follows:
    I setup for my power supplay starting after igintion (mode 1 = 5 sec after start). I have tested everything on my desk many times (with 12V power converted from 220V). Everything is working well on my desk, but IN MY CAR NOT! I checked all cables, everything seams to be ok.
    I read some information about changing the polarity of J8 cable (didn't help) or checking the resistor R4 (did not checked yet, need some loupe) or that there is something with the ground.
    I can't replace the M2-ATX power supplay because I bought it long time ago and mounting right now. I bought it abroad and I don't want to wait for shipping. I don't want to replace it to opus, too. I will have to wait for shipping and waste some money again.
    It there some easy, clear and final solution to this problem, which I can applay myself??
    Mar 2006
    Colorado, but Canadian!
    Did I miss the actual problem?
    I see some steps you took to try and solve it, but I think you forgot the problem you are having....
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2005
    The problem is that in the car the M2-ATX doesn't start the computer. When the power is delivered the led is blinking and when the ignition is turned on then the led lights constantly but the computer doesn't start (no funs running, no beep from the mainboard and etc.).
    On my desk eveything works ok but in the car not.
    I don't want to replace resistors and etc. before I will not make sure that this is solution.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    How are you powering it at your desk? You should be able to get it working at your desk using the M2 and all before putting in your car. There are faqs on powering up from dc supplies at home.
    ~Jimmy
    Nov 2005
    Yes exactely, I checked it on my desk and it is working but in the car not.
    On my desk I'm using power supply like: http://www.ctek.com/EN/MXS7000/features_benefits.asp (in supply mode).
    I don't know may be there is something in voltage differences, like in car there is something like: 12,6V and at home is a bit higher.
    Is it possible? Did anybody has such problems?
    Elsewhere
    have you measured the voltage on your +12v line, as well as your ACC line (while both off and on)?
    What guage wire are you using to provide power?
    Have you checked fuses?
    How about the Wiki?
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    flip J8
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Quote Originally Posted by m_michal View Post
    If its voltage difference, just start your car, should give all the power you need.
    Nov 2005
    I know it's strange and stupit but it doesn't help, too.
    Even if I start the car.
    I flipped also the J8 and still the same.
    I opened the case and check if there is everything ok and after ignition the voltage
    is given.
    Does anybody know maybe what indicates the M2-ATX led when it is lighting constantly?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    what happens when you dont connect J8 but short the 2 pins on the motherboard instead ? does the pc turn on?
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 08:04 PM
  2. M2 ATX with remote starter question?
    By david69leonard in forum Power Supplies
    Last Post: 02-05-2007, 05:50 AM
  3. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 03:06 PM
  4. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 05:22 AM
  5. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 06:48 AM
