Results 1 to 3 of 3
Thread: Opus compatible?
    Low Bitrate AltimateX's Avatar
    Mar 2007
    Wisconsin
    Opus compatible?
    I took the parts for my carpc from a HP a245c. The opus 250 says its for AT, ATX, uATX, FlexATX, Mini ITX motherboards.
    I am not sure if this is compatible with my motherboard. I bumped into this psu http://logicalplus.stores.yahoo.net/at20mihpcore.html and it says its compatible with microATX and my HP model is listed as compatible computers. I am assuming this means my motherboard is ATX and I can use the Opus, correct?
    If not, am I going to need to use something like this? http://store.mp3car.com/Carnetix_CNX..._p/pwr-026.htm
    Thanks!
    Elsewhere
    you need to determine if the motherboard is 100% ATX compatible.
    Open it up and look for teh 20-pin connector on the motherboard. IF that's there, then it's likely that the Opus will work.
    The only way to be 100% certain is verify the pinout of the HP PSU is the same as AT standard.
    You can also see if the existing PSU is ATX comatible. There shoudl be a label on the side that will give you that information.
    I'm pretty sure that the Opus will work for you. But you still need to do the leg work so you can be 100% certain.
    How about the Wiki?
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    i have a micro-atx board and I have make an opus 150 works fine. make sure its 20-pin. my new board I have is micro-atx but it has 24-pin, still works
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. I hate Car PCs!! Opus Problems!!
    By Anees in forum Power Supplies
    Last Post: 12-01-2005, 09:26 PM
  3. WTT: Opus 150 for Opus 120
    By Shelbrain in forum Classified Archive
    Last Post: 11-18-2005, 06:47 PM
  4. Opus stays on in standby
    By camarossguy2 in forum Power Supplies
    Last Post: 08-10-2005, 12:31 PM
  5. Opus not powering on VGA/Sound
    By TheGeneral in forum Power Supplies
    Last Post: 10-04-2004, 02:01 PM
