Results 1 to 3 of 3
Thread: Power Cables to PSU and Amp
    Aug 2007
    I am powering a Carpc via a DSX12VD and a Sony Xplod Amp 250w, i am going to run separate fused power cables from the front of the car to the rear. Is there any issues with running them side by side, i'm thinking about heat/interference etc.
    thanks
    Mar 2006
    Colorado, but Canadian!
    As long as they are both power cables they wont interfere. Well they wont interfere in the human size range.
    And for heat, as long as the cable is a low enough guage (meaning thick enough wire), it will not heat up very much. The more current through the same wire, the hotter it gets, and more likely for damage.
    I am sure you calculated the power draw, and chose wire guages accordingly?
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    if anything the wire is over the top, PC rated at 15A, Amplifier at 30 amp, wire rated at 45A and i'm using the same for both,
    cheers
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. psu to power amp and speakers?
    By qaz in forum Car Audio
    Last Post: 05-31-2005, 10:27 PM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
