Results 1 to 9 of 9
Thread: M2-ATX Hibernation & jumper issue
    Sep 2007
    have just connected up my m2-atx to epia m10000 mobo on my desk at home
    it works fine & ive tried all the jumper settings which work a treat
    i wanted the m2 atx because of its shutdown controller but i am now wondering after reading the manual:
    1) if i enable hibernation & choose an offdelay of 30mins the manual says there is never a hardoff in this mode - will this drain my battery ?
    2)what are the preactical uses of jumper settings 1-5? surely if the m2atx is gonna push the power button on the mobo after 5 or 30 seconds this may as well be just shutting down when you turn of the ignition? i mean what can you do in that 30 seconds?
    i wanted the m2 atx so i can stop at the shop & i wont have to reboot when i get back in the car & also so i can park outside the house & will have a while to access the carpc on my network - can anyone tell me the best config for these applications?
    Mar 2006
    Colorado, but Canadian!
    I like the 30s/2hr option with standby. Instant music pretty much as long as the car has been turned on within 2hrs. The hardoff times are the "pull the plug". The softoff times are the pressing the power button which would be standby/hibernate/shutoff depending how you set it up.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2007
    thanks, that solves the problem of the reboot then when parking at the shop/garage
    but with regards to mode 6 (30min offdelay & hardoff never), will this run the battery flat in hibernate?
    Mar 2006
    Quote Originally Posted by jimiboboyo View Post
    why would you set it to off never if you are using hibernate?! Hibernate can survive with no power as it writes to the HD which keeps its state no matter the power. You dont have to reformat your OS everytime there is a power failure!
    Most of the time you wont have a problem, but (everyones favourite word...) if the PC fails to shutdown it will continually drain the battery dead. If there was a hardoff, then if the PC failed to shutdown, it would pull the plug after a bit, and the battery would be ok.
    Sep 2007
    the ony reason i wanted to set it to hardoff never is because the only mode where you can have it press the power button after 30 minutes has no hardoff setting
    because i want the system to be able to continue running after i park outside the house so i can transfer files from my home pc to the car - the only settings which would allow me to do this are 30 minutes with no hardoff & 3 hours with no hardoff.....there are no other settings which would allow me to do this
    also with regards to your advice re standby, i just tried this & the stystem went into standby when turning ignition off but didnt resume when i turned it back on... also, do the fans continue to run in standby???
    Mar 2006
    The fans should not run in standby, and that is software config problem on your end. Usually the video drivers, or you have to enable S1 and S3 in the BIOS.
    And there are other settings than what are listed in the manual. They are posted somewhere on here, but I dont know where. Total of 16 modes.
    Sep 2007
    thanks ill look into it & post my findings
    Mar 2007
    Quote Originally Posted by 2k1Toaster View Post
    is that the one that is "recommended" on the m2 atx instuctions?
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    The recommended is 5 sec/2hr. I have mine set to 5sec/never because I have a gel battery (Wonderful stuff ) When I hibernate, my GPS still has lock on sats and a couple of USB devices have power also while on standby. According to the power math, I can leave the M2-ATX on NEVER for a little over 3 days w/o starting my vehicle, Besides, the unit goes to hardoff after the voltage drops 11.2 and still my battery would have 106 minutes of reserve power for cranking.
  1. m2 atx
    By slantman in forum Power Supplies
    Last Post: 08-08-2007, 04:45 AM
  2. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 10:36 PM
  3. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 02:16 AM
  4. new board atx issue
    By Gibby in forum Power Supplies
    Last Post: 04-12-2005, 07:50 AM
  5. Hibernation Issue!!
    By autopilot747 in forum Newbie
    Last Post: 03-23-2005, 10:34 PM
