Results 1 to 3 of 3
Thread: Lowering gauge of cable?
    Jun 2007
    Oxnard, CA
    Well this is probably a very simple question but I am having a very hard time finding a good answer.
    I have a 4 awg cable going to a distro block in my trunk and then a 8 awg cable leading to an M2-ATX. Only problem is the cables on the M2 are 18awg... The distance is only across the trunk.
    I am thinking just strip both wires and solder them together (just like any other thing). My only fear is there being a problem with having the smaller cable connected.
    Any points in the right direction / advice would help ^_^
    Mar 2006
    Colorado, but Canadian!
    Generally speaking you should fuse when you switch guage sizes.
    But in my opinion if you solder it, then you should fuse at the battery, at the distro block and then the onboard fuse of the m2.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    Oxnard, CA
    perfect thats what happening ^_^
    Thanks man
  1. Laptop TTL LCD cable extension
    By Dranger in forum LCD/Display
    Last Post: 08-21-2006, 03:01 PM
  2. 2.5" IDE cable question...
    By SamDude in forum General Hardware Discussion
    Last Post: 01-13-2006, 05:49 PM
  3. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 04:45 PM
  4. Replies: 22
    Last Post: 03-09-2005, 11:27 AM
  5. vga cable for lilliput
    By JaxPt in forum LCD/Display
    Last Post: 02-24-2005, 11:52 PM
