Results 1 to 10 of 10
Thread: Dc-dc
    Oct 2007
    Dc-dc
    Hi,
    I just bought a Travla C158 on the net and it comes with a PSU 60W so my question is:
    Is it a good PSU to plug in direct from the battery or should I use the M2-ATX 160W?? I'm kinda confused in what that PSU 60W is and what I need.
    Thank you
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I believe the 60w internal psu only converts 12v to all the required voltages for the system. If this is the case, then connecting it directly to the battery would probably be a bad idea.
    Oct 2007
    So I definetly need a DC-DC M2-ATX
    Jun 2003
    Fairfax, VA
    Or a laptop auto adapter that will output 12v.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by binary.h4x View Post
    And a shutdown controller.
    Oct 2007
    You means like an AC Adapter External? 12V 5A?
    Oct 2007
    I'll take a picture of my psu tonight and you will be able to tell me if i'm okay with that
    Oct 2007
    Here is the picture
    May 2005
    Denmark
    Your power supply does _NOT_ regulate the 12 Volts, so when the voltage in your car jumps up and down you will fry your parts in the computer - DON'T do that!
    Been there, done that - got the t-shirt!
    Look after an M2 ATX - it has integrated Shutdown Controller too.
    // Per.
    Oct 2007
    Actually, I did bought a M2-ATx. It's coming right now
    Thank you
  1. wich is better for me "ac to dc or dc to dc"
    By Iguana2020 in forum Power Supplies
    Last Post: 07-06-2006, 11:07 AM
  2. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  3. DC to DC converter
    By jdub421 in forum Power Supplies
    Last Post: 02-03-2004, 04:17 AM
  4. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 05:25 PM
  5. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
