Results 1 to 3 of 3
Thread: Question for Zootjeff, What's the DSATX white wire for?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Exclamation Question for Zootjeff, What's the DSATX white wire for?
    Question for zootjeff on the dsatx.
    The pdf manual shows pin 18 as N/A but there is a white wire installed in the molex. The white wire in an atx supply is supposed to be -5v from what I can find out.
    Is there voltaage at the white wire or is it unused (dead wire)?
    I ask because my original ps did not have the white wire. From what I can discover, the -5v rail is for isa legacy devices. Is this correct and can I just remove the white wire on the 20 pin atx molex?
    Leonardo Da Vinci
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i believe that newer motherboards don't use -5v anymore..
    May 2007
    Correct.
    Problem already sorted.
    Thanks.
    Leonardo Da Vinci
  1. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  2. Question about wire to connect to battery
    By thanassius in forum Power Supplies
    Last Post: 08-07-2006, 11:35 AM
  3. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  4. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
  5. LCD wire question
    By Axkicker in forum General Hardware Discussion
    Last Post: 02-25-2001, 11:23 PM
