Results 1 to 8 of 8
Thread: Odd power supply
    Oct 2007
    Odd power supply
    Hello-
    I've got a bit of a noddle scratcher, and I thought you all would be the best people to ask.
    I've got a gadget I want to mount in my car. After looking at the power adapter, I found that the output is 12V AC, not DC. Is there a way to power this from my vehicle without having to plug it into a bulky inverter? My inverter is mounted far from the dash, which is where I plan to install the unit, so it makes it difficult to just plug it in.
    Any ideas?
    Thanks in advance!
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    look in the gadget and see if it rectifies it as the first thing on the board. If so, the chances are you can feed it DC, perhaps bypassing the rectifier to eliminate the voltage drop (and ground offset if full wave bridge) of the rectifier if necessary.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    What is it?
    A door bell is the only thing I can think of that might use 12 v ac.
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by billmee View Post
    What is it?
    Add rs232 boards to your list of devices using ac : http://www.mp3car.com/vbulletin/powe...vdc-12vac.html There are many more devices too.
    Of course I'm not saying that the device in question here is an rs232 board.
    Oct 2007
    It's a radio scanner.
    In reply to Rob W: Totally over my head dude. Mind dumbing it down a bit? If it helps, Here is the parts list. May make the solution more obvious.
    Thanks for the replies, keep 'em coming!
    --T--
    May 2005
    Denmark
    Quote Originally Posted by 90whiteRunner View Post
    --T--
    A parts list is not enough to find out if it rectifies the input voltage.
    A diagram would be nice, or a picture of the input portion of the circuit board.
    Else, try to feed it with 12V DC, nothing bad will happen. Either it works, or it doesn't - Easy!
    The polarity of the 12 V DC is not important in this situation.
    // Per.
    Oct 2007
    I'll try to remember to take a picture later today. I'm nearing the end of my shift(Yes, it's 7am and my shift is nearing the END...), so when I wake up later I'll try to post a pic.
    Thanks again for the replies.
    --T--
    Oct 2007
    Well, it worked when I put 12vdc into it. guess that solves that.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  3. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  4. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
