Results 1 to 3 of 3
Thread: Carnetix 15W +5V adapter...
    Nov 2005
    Hey Everyone,
    I have a quick question. Since I lost my cig lighter when I installed my screen, I would like to relocate it. I have a Carnetix P1900 with the 15W +5V P.O.L. Can I simply wire this to a cig lighter, and its good to go?
    I just use it for charging my cell phone, FM Transmitter etc.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    The Carnetix just converts 12v to 5v. You can plug it to any line that carries 12v (like the cig lighter) and it'll work. I thought that the main reason for getting that POL was to power USB devices.
    Mar 2007
    Your normal cig lighter is 12v, the carnetix will give you your PC output (12 - 19v IIRC) screen output (12-13v) and additional output (5v).
    A lot of devices are designed to charge on 5v so they can work with USB and therefore most cig plugs have a 12v -> 5v regulator in them.
    If you just want to charge things that have a USB or 5v input then you could put a powered usb hub and/ or wire directly to the power lead for the item. If you want a general purpose cig lighter socket, then you'd be better just taking it straight from the car electrics and ignoring the carnetix - if you fed your cig lighter from the carnetix you'd have to make sure not to use a power inverter, car powered vacuum, powered tyre inflator etc etc
  1. New Open Source Valentine One USB Adapter Design
    By PredatorCoder in forum Hardware Development
    Last Post: 06-21-2009, 12:21 PM
  2. Carnetix P1900/P2140 and IBM T40 Laptop Power Question
    By l00kster in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-24-2008, 01:55 PM
  3. 12V, 5A Regulated Car Adapter
    By Alta in forum Power Supplies
    Last Post: 03-03-2005, 12:02 PM
  4. Alpine aux adapter issues
    By oekundar in forum Car Audio
    Last Post: 11-22-2004, 01:50 PM
  5. slim slot dvd rom with wrong adapter, questions
    By mattress in forum General Hardware Discussion
    Last Post: 10-24-2004, 08:51 PM
