Results 1 to 3 of 3
Thread: installing a powered USB Hub.....questions?
    Mar 2007
    Hi guys,
    Im goign to be installing a powered USB Hub. Searched around and saw a device that can be used to convert the 12V to 5V, but it seems like it only worked with a certain power supply. If i found the 5V wire coming off of my PSU, if i tapped into that, would that work just as good?
    thanks in advance
    _
    Mar 2004
    Little Elm, Texas
    would work just fine
    Jan Bennett
    Mar 2007
    sweet, thanks!!
  1. USB hub problem always disconnecting / connecting
    By fire in forum General Hardware Discussion
    Last Post: 09-25-2009, 03:30 PM
  2. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 09:16 PM
  3. WTB: USB 2.0 Hub powered from 12v
    By JoyRidun in forum Classified Archive
    Last Post: 11-05-2005, 10:07 PM
  4. Molex Powered USB 2.0 4 Port Hub!!!!
    By Heckle0 in forum General Hardware Discussion
    Last Post: 06-22-2005, 03:49 PM
  5. USB Hub stays powered when I turn off car...any resolution?
    By Mears in forum General Hardware Discussion
    Last Post: 07-07-2004, 08:42 PM
