Results 1 to 6 of 6
Thread: Pulse start P1900
    Constant Bitrate enigmacarpc's Avatar
    Feb 2007
    NJ
    Pulse start P1900
    Does anyone know how to hook the pulse start wire up to a keyless entry?
    I have a 2005 Infiniti G35 Coupe.
    Also if anyone knows where the ignition line not the acc line is in the g35?
    Elsewhere
    You can get wiring information at http://www.the12volt.com (among others).
    Any power line that is switched by the ignition will work for the IGN line for the P1900.
    How about the Wiki?
    Feb 2007
    NJ
    Man you are fast with the reply I was under the impression that it had to be the ignition wire.
    4.2.1 What is a pulse?
    Voltage Pulse on Pin 1 of J1
    When connecting to Pin 1 of J2, the “pulse” must be a voltage that transitions from 0V to +V, and then transitions back to 0V. The SSC will wait (hang) if the voltage stays high without going back to 0V after the initial transition from 0V to +V.
    The value of the +V can be any voltage from approximately +2V to +20V. Typical voltages are +5V or +12V. The value of 0V must be below +.2V or open circuit (ie you could drive this input with a relay that momentarily connects to a +12V source and then provides an open circuit).
    Thanks for the help.
    Nov 2007
    Pulse start P1900
    Fuel Injecters Wires Have Pulse
    Elsewhere
    Quote Originally Posted by EAUTOMANX View Post
    Which is completely and utterly useless for a vehicle computer.
    How about the Wiki?
    Feb 2007
    NJ
    I talked to an installer he said I may need to tap of the door lock motor.
  1. P1900 not working??
    By makaufmann in forum Power Supplies
    Last Post: 10-11-2007, 08:30 PM
  2. Powering P1900 in your house?
    By fpena in forum Power Supplies
    Last Post: 06-04-2007, 08:29 AM
  3. standby problems with p1900
    By hovalistic in forum Power Supplies
    Last Post: 02-01-2007, 02:55 AM
  4. FS - Carnetix P1900 140w Dc-Dc PSU (AUST)
    By NiSlo in forum Classified Archive
    Last Post: 11-09-2006, 11:59 PM
  5. Car won't start after carputer install
    By UnsanePyro in forum General MP3Car Discussion
    Last Post: 07-24-2005, 04:44 PM
