Results 1 to 8 of 8
Thread: power fault in carpc
    Oct 2007
    mazda 6 carpc monitor stop
    hi
    i have carpc for mazda 6 and i connect the power wire in wrong way
    red with black
    black with red
    it is stop work and see same smoke
    what problem and what is part in borad need 2 change ??
    Oct 2007
    hi
    red with black
    black with red
    Oct 2005
    Uhmm, you connected the power to ground?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    You need to replace at least the part that smoked.
    I hope your soldering skills are good.
    TruckinMP3
    Read the FAQ!
    May 2007
    You connected the wires in the wrong way so more than likely you have blown the whole system so you will have to get new equipment sorry to tell you this.
    Elsewhere
    Quote Originally Posted by Zo6om View Post
    hi
    red with black
    black with red
    The problem is that you applied power with reversed polarity....
    Your power supply is toast, at the very least. It's possible the whole PC is reduced to a paperweight.
    Rather than identifying wires by their color, it's a far better idea to refer to them by their function (+12v constant, +12v switched or ground).
    Oh yeah. QUIT CROSSPOSTING!
    How about the Wiki?
    Oct 2007
    yes only motor for open and close the monitor it is work
    monitor screen off
    Jun 2002
    Colorado
    monitor screen off
    Mostly when you let the magic smoke out of electrical components it is replacement time.
    TruckinMP3
    Read the FAQ!
  1. Replies: 1
    Last Post: 01-09-2007, 06:57 AM
  2. How to power carPC from AC outlet
    By buurin in forum Newbie
    Last Post: 11-04-2005, 07:45 PM
  3. P 1280 AND an inverter to power my carpc, make sense?
    By Will Albers in forum General MP3Car Discussion
    Last Post: 05-24-2005, 11:50 AM
  4. Power up carpc in home
    By czal in forum Newbie
    Last Post: 05-13-2005, 12:23 PM
  5. HELP on Using Inverter and UPS to power carpc
    By davidbudi in forum Power Supplies
    Last Post: 04-27-2005, 10:36 AM
