Voltmeter not necessarily will show correct voltage, you have to put any load on the PS, and then try to measure. Check, and re-check connections first, see what happens when you turn ignition off and remove the key, that led should blink or so (see manual).
Even if you short the output, it's unlikely that you fry it. If everything else fail, you can deem you PS fried![]()
LinkBack URL
About LinkBacks
