Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Please help with Opus auto power problem
  1. #11
    Jul 2006
    I disconnected motherboard from power supply then it won't turn on, but when PC is ON I got 12.05V and 5.08V from the yellow and red wire on HD connector.
    I monitor the continuity on J7 PWR-SW, when I turn on the IGN switch, there's no sign that J7 is shorted, maybe my Opus is bad?
  2. #12
    Jul 2006
    It looks like it's working now on my test bench but I'm really confused. From Dell Dimension 4550 user manual it says:
    Suspend Mode
    The options are S1 or S3.
    AC Power Recovery
    Determines what happens when AC power is restored to the computer.
    * Off (default) The computer remains off when AC power is restored.
    * On The computer starts when AC power is restored.
    * Last The computer returns to the AC power state existing at the time
    that AC power was lost.
    So I should be setting S3 and Off for the above two settings, but I changed it to S3 and On and now it's actually turning on or resume my PC and hibernating when I switch off IGN.
    What's going on???
  3. #13
    Oct 2007
    i have this psu. its fine. what size cable do you have going to the power. have you calcuated your power req properly. iv got 4 guage wire to mine. i think the pc powers up. it sucks juice. and then shuts down because of the thinness of the wire. cig liters arent really a good source for power supplies. also read the manual. you may have some jumper setting wrong
    http://www.opussolutions.com/index.php?p=product&id=46
  4. #14
    Jul 2006
    Talked to Opus support about this problem and we went through couple tests to verify the Opus is ok and functional, voltage check on all input/output wires but still couldn't get a final conclusion. The only thing left now is to check if Dell dimension 4550 is ACPI version 2 compatible or not.
  5. #15
    Newbie jdamb89's Avatar
    Jun 2007
    Miami, Fl
    Msun, did you ever find a solution to your problem?
  6. #16
    Jul 2006
    No actually I just use it as-is for half year now and it seems fine. I never found out whether the Dell 4550 is ACPI version 2 or not since Dell's support doesn't know either.
    Besides PC turns on by itself when I connect the battery, it starts up and hibernates normally when I turn the key on/off. AC Power Recovery is set to "ON".
  7. #17
    Jun 2007
    Miami, Fl
    Interesting. I've been having the same problems with a Dell 8200.
    So the only thing you changed to make it power on is to set AC Power Recovery to "On"? I'll give that a shot.
  8. #18
    Jul 2006
    Cannot believe that after 6 years I'm actually benefit from my own post 6 years ago.
    The CarPC ran fine for 6 years and finally gave up because the motherboard has 4 capacitors exploded. I had two Dell 4550 and I used the other one as my linux server so I retired my linux server and use it to replace the dead motherboard in the car. Tested everything on workbench with a PC PSU which worked fine, with BIOS set to S3 and Off, move it to the car then the same weird thing I experienced 6 years ago happened again, it hibernates fine but just won't power up right, fan spins for a split second then shuts off. Tried S3 + Last and S3 + Off and nothing worked. I have been puzzled for the last two weeks because I thought it would be an easy swap. Until I find my own post from 6 years ago..... God bless this forum
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 06:31 AM
  2. Opus DCX3 120 problem. Fans spin, LED on, no video
    By Gene in forum Power Supplies
    Last Post: 02-27-2008, 07:27 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 04:13 PM
  4. Opus 90W Problem: No led flash, doesn't power up
    By Macklion in forum Power Supplies
    Last Post: 01-18-2005, 10:21 PM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 01:32 PM
