Results 1 to 10 of 18
Thread: Please help with Opus auto power problem
    Jul 2006
    I just hooked up the PC and everything in my car, there are still lots of issues need to be addressed, but the basic power problem is bothering me and I can't seem to find an answer so was hoping someone can point me to the right direction.
    I am using Opus 320W to driver a Dell 4550 MB, IGN signal is connected from cigarette lighter 12V+. I measured voltage on the power wire from PC end it's 12.53V, same as what I measured from battery. IGN voltage at PC end is 11.85V so everything looks fine.
    When key is in OFF position:
    - Opus blinks slowly
    Turn key to the ON position:
    - Opus blinks faster
    - PC fan and hard drive spins for a second then shuts down
    If I short the two pins from MB where I plugged in the power control cable (while they are still connected) then PC boots up fine, everything works from there.
    Turn the key OFF again:
    - PC shuts down instead of hibernating, Opus back to steady blink.
    I checked the BIOS setting the power management is set to S3, but couldn't find out why it does not power on the PC. If anyone has any ideas please help...
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by msun View Post
    Is the power control cable the right way round?
    Did you set it to hibernate in control panel?
    Jul 2006
    I tried switching the power control cable around but it doesn't make a difference...
    Sep 2007
    What pins do you have shorted and open on the opus?
    I have the 120 and there are two yellow and two black wires. If both yellow are not hooked up to constant 12v then it will not work. The RED wire should be connected to a switched 12v. Do not apply 12v to the red until after you have seen two quick green flashes of the light on the power supply. It will not power up if you apply 12v to the red and yellow on the first power up.
    Jul 2006
    I believe I shorted the green and white wire on the Opus, but I actually shorted the IC board from the PC where the green and white wire goes to.
    Jul 2006
    From Opus's FAQ:
    When applying power for the first time you need to wait for the first blink of the LED before applying power to the switched (IGN) lead.
    Does that mean when I turn the to ON position, I should have some kind of delay between my cigarette lighter hot wire and Opus??
    Sep 2007
    This is only for the very first time you apply the constant 12v to the power supply.
    So:
    1. Connect the wires for constant 12v
    2. Wait until the power supply starts blinking. I believe it's two short flashes.
    3. Then apply the switched 12v power.
    Even without a motherboard attached it should turn on if you jump the green and white wire for a moment. If it won't turn on that way then you either have low voltage or some other problem. The lights flashing should indicated which error.
    Jul 2006
    Should I be expecting any voltage from the green/white (J7 PWR-SW) wire once I connect IGN?
    After I supply IGN with 11.75V, I don't see any voltage from green/white cable. I manually hibernated my PC, the LED on Opus is blinking every 2 seconds, I switched off IGN, wait for 10 seconds then switch ON again, PC turns on for a split second then shuts off, LED on Opus now blinks every 1 second. Opus manual does not say what it means for 10 blinks for every 10 seconds
    Also, when PC is on, I measured 3.26V constant voltage from the power button on PC, not sure what that means...
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Is the BIOS set to power PC on after power applied? This should be set to off.
    Possible scenario:
    IGN goes high, Opus supplies power to PC, PC turns on automatically (due to BIOS setting).
    Opus presses power switch, PC turns off.
    This could result in a split second of PC on before the Opus switches it off.
    Rob
    Sep 2007
    Again I don't have the exact same power supply. But the green and white wire "The jumper wire between the power supply and the PC motherboard" should be connected to the power button pins on the system board. No, there is no voltage. It's simply a momentary short.
    Try disconencting your motherboard from the power supply and see if it turns on and stays on then.
    My first powersupply did the same thing yours is doing. I would get about a half second on and then off. Turns out the 12V rail from the power supply was bad.
    If you have a volt meter you can test it, you should get 12V on the yellow Hard drive connector and 5v on the red. If either is low then the power supply bad.
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Opus DCX3 120 problem. Fans spin, LED on, no video
    By Gene in forum Power Supplies
    Last Post: 02-27-2008, 08:27 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. Opus 90W Problem: No led flash, doesn't power up
    By Macklion in forum Power Supplies
    Last Post: 01-18-2005, 11:21 PM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 02:32 PM
