Results 1 to 10 of 10
Thread: DSATX Power My Setup?
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Question DSATX Power My Setup?
    I am getting ready to put my carputer together, but still need a PSU. I was thinking i would get a DSATX 220w beacause i am worried about if it will be able to power my setup.
    My setup is as follows:
    Micro ATX Motherboard
    AMD Athlon XP 2500+
    RAM 1.5GB (DDR PC3200)
    IDE HDD 40GB
    Sound Card - Onboard
    Video Card Onboard
    DVD-RW External Slim
    USB 4-port Powered Hub
    USB GPS
    USB Bluetooth Adapter
    AM/FM Receiver
    Wireless Ethernet Card
    DSATX 220W DC-DC intelligent power supply
    I am powering my monitor to the 12V Molex connector on the DSATX.
    I am also powering my hub with the 5V Molox connector on the DSATX.
    I have tried the following power calculator and i get the following wattage:
    215 Watts.
    http://www.journeysystems.com/?powercalc
    I just want to make sure everything will power ok since i am powering my hub and monitor on the DSATX PSU.
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Quote Originally Posted by TeamRSX View Post
    AMD Athlon XP 2500+ (68w)
    RAM 1.5GB (DDR PC3200) (20w)
    IDE HDD 40GB (25w)
    Video Card Onboard
    DVD-RW External Slim (5w)
    USB 4-port Powered Hub (20w)
    USB GPS (5w)
    USB Bluetooth Adapter (5w)
    AM/FM Receiver (usb? 5w)
    Wireless Ethernet Card (usb? 5w)
    I am powering my monitor to the 12V Molex connector on the DSATX. (<10w)
    How many total usb devices? Not the powered hub, but how many devices? You stated the DVD, the GPS, the bluetooth, and a usb hub (I made it maxed out).
    On-board vid/sound.
    Even at 100% max CPU usage, I'm getting the estimation of 168w
    So most of the time, you should be under 150w, besides during startup. (give or take some power consumption, depending how you answer the above usb question).
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by Phatsacks View Post
    On-board vid/sound.
    My total usb devices are 8. which includes the following:
    GPS, Bluetooth, Wireless Ethernet, External DVD, USB Touchscreen for Lilliput, 4-port USB Hub, Keyboard, mouse.
    You made the wattage max out with the above items?
    I have a total of 4 usb ports on my mobo and 4 usb ports on my hub.
    How are you getting 168w? Everytime i check i get over 200w with the link i provided.
    May 2007
    Springfield, Va
    Type out what you are adding up (the amounts for each)
    Nov 2007
    Ottawa, Ontario
    Here are the amounts for each on my items:
    ATX Motherboard - 25W
    Keyboard + Mouse - 3W
    CPU Fan - 3W
    AMD Athlon XP 2500+ - 68W
    IDE Hard Drive - 25W
    1GB DDR RAM (2 Sticks) - 20W
    External DVD Rom - 10W
    Lilliput Monitor - 10W
    GPS Receiver - 5W
    Bluetooth Adapter - 5W
    Wireless Adapter - 5W
    4-Port Powered Hub - 25W
    Total = 204 Watts
    I know these numbers are not accurate and i may be off on some of them, but please let me know how you came up with 168W because there is quite a differnece in our numbers.
    Thanks for your help.
    May 2007
    Springfield, Va
    CPU Fan - 3W
    GPS Receiver - 5W
    Total = 204 Watts
    Well from my understanding, and hopefully a confirmation one or the other is posted, a motherboard pulls up to 30w, which includes keyboard/mouse and cpu fan.
    Your 4 port hub, should only pull the 4*5w, which is 20w.
    Your slim dvd drive should only be 5w also.
    So using your above list:
    Keyboard + Mouse - includedW
    CPU Fan - includedW
    External DVD Rom (slim you originally said)- 5W
    Lilliput Monitor - <10W
    GPS Receiver - 5W
    4-Port Powered Hub - 20W
    25+68+25+20+5+10+5+5+5+20
    Max = 188 (I actually forgot the HD in my original)
    So it should be 188 max, give or take some.
    Which is only at startup anyways, so you should easily be under 160w most of the time.
    But if I'm wrong (good chance I am), you can always buy an M1 or M2 to power some of those devices and take some of the load off your dsatx.
    Nov 2007
    Ottawa, Ontario
    Looks good to me.
    I had the hub wattage wrong and is 5watts x 4 ports.
    Well, all said and done i think i will be ok with the dsatx 220w psu.
    If anyone else can clarify these numbers that would be great also.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i had more on a m2-atx... ull be fine with 220watts
    Live mp3Car Facebook Chat
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Sonicxtacy02 View Post
    I thought the m2 was only 160 watts?
    I'll be running a ATX/AMD 3200+/ATI 9700Pro in my car soon...I have no idea how much power I'll be drawing
    Oct 2007
    Im running
    Amd sempron 3.4g
    1g ram
    160gb hdrive 3.5
    40gb laptop drive 2.5
    onboard sound + vid
    Usb Bluetooth gps dongle
    Usb Keyboard
    Usb Wireless mouse
    Usb Dvd rewriter But powered from external suply
    Usb wifi dongle
    And 7" Linixt touchscreen monitor powered from supply too
    All powered from M2ATX
    Had no problems here whatsoever.
  1. Power Setup W/ Laptop and K301
    By OUSilver05 in forum Power Supplies
    Last Post: 12-13-2006, 10:40 PM
  2. Will M1-ATX power this setup
    By efim13 in forum Power Supplies
    Last Post: 12-29-2005, 12:36 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Power setup scenario - Suggestions?
    By Coeus in forum Power Supplies
    Last Post: 01-16-2005, 04:30 PM
  5. temporary carpc, will this power setup work?
    By bobthebaker in forum Power Supplies
    Last Post: 10-11-2004, 04:21 PM
