Results 1 to 10 of 11
Thread: I'm out of ideas (Sproggy mk2.8/+ ???)
    Maximum Bitrate GuRuGoD's Avatar
    Jun 2002
    Omaha, Nebraska
    Alright i need your guys' help here. I have a sproggy mk2.8 build and modded with the transistor and resistor to make it the 2.8+.now, if I manually ground pin14 the relay clicks and the LED lights up. No problem right?
    Well, when I plug her into a mobo, and hit the power switch, nothing happens. I have tried the board with a different PSU in the same conditions and it works fine.
    Playing around with a volt meter i noticed that when the normal psu is plugged in and i hit the power switch, pin14 is grounded for a split second and then is disconnected. This may pose a problem in that, in order for the sproggy to stay on... I have to keep pin14 grounded.
    Not sure if I have ben clear enough, but I would appreciate any help.
    P.S. I have checked the polarity and they all seem correct. I have also checked all of the output voltages and they also seem corrent.
    90% Done
    60W DC-DC & shutdown controller
    Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
    Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
    All in a shiny White 2000 V6 Mustang
    Click here to visit my NEW PhotoAlbum
    FLAC Mastero's Avatar
    Aug 2001
    India
    when i designed the 2.8+ i noticed that the pin 14 goes ground and stays ground ..
    so i wonder whihc mobo you have .. try the 2.8+ with a different mobo
    Mastero
    Jun 2002
    Omaha, Nebraska
    I've got the VIA EPIA C3 (sig). I know there are others using this combination of parts? Would someone be kind enough to let me know if this is board behavior or PSU behavior?? I will try it with another board and keep you posted.
    90% Done
    Jun 2002
    Omaha, Nebraska
    Alright, tried sproggy with 2 other boards...nothing. I get the same eerie silence i did before. Any suggestions?
    90% Done
    Aug 2001
    India
    Gurugod this is strange ..
    for the 2.8+ to work perfectly you will need constant ground on pin 14 of the atx connector .. which i suppose your not getting for some reason .. check the mobo and see if they are giving constant ground or just pluse of ground ..
    Mastero
    Jun 2002
    Omaha, Nebraska
    OK heres what happens when I use a regular power supply with my VIA EPIA C3.
    1) I plug the PSU into the wall
    2)At this point PIN14 on the connector has 3.3V
    3)I attach the ATX connector to the mobo
    4)Immediatly, Pin14 has 4.2 volts
    5)I hit the power switch (touch the two pins on the mobo)
    6)Pin14 is fed 90mv (which I assume is ground)
    7)Everything powers up
    8)PIN14 stays at 90mv until I power down
    Now heres what happens when I go through the same process with the sproggy:
    1) I wire up the 12V, ACC to my bat and ground to the bat
    2)At this point, pin14 has 4.5V
    3)I attach the atx connector to the mobo
    4)immediatly, pin14 has 4.28V
    6)nothing, pin14 remains at 4.28V
    This tells me that the board will deeliver constand ground under normal circumstances. THere must be something wrong with the sproggy. Here's what the sprogggy outputs when all i have connected is 12V, ACC and ground
    All pins read 0.00-1.2mV except pin 14 which reads 4.5V and pin8 wihch ocilites around between 40mV and 80mV quite sparatically.
    Seee any problems there? Are these the volatges I should have when teh psu has power but is off?
    90% Done
    Aug 2001
    India
    ok you will have to get me these readings
    PIN9 = ?
    pin 8= ?
    pin14 = ?
    First connect the sproggy to the battery
    check all the volts in all the mobo pins ..
    Then connect ground to pin 14 and see if the sproggy kicks on if it does then check the volts again for all the pins on the ATX connector.
    what i feel is you are not getting the 5v stby.
    Let me know
    Mastero
    Sep 2002
    Just North of Toronto, Ontario, Canada
    Try holding the power switch in for 2-3 seconds. I had a cheap atx supply that would come on when i pressed the button, but wouldnt stay on, then i found out that if i hold the button on for about 3 seconds, it will stay on.
    I know it has nothing to do with the sproggy, but it could be some soft of motherboard issue.
    btw, ive got an Abit BX-20 (OEM).
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    Jun 2002
    Omaha, Nebraska
    PIN9 = ?
    pin 8= ?
    pin14 = ?
    Let me know
    Mastero
    Ok, with 12V, acc and ground connected to the battery, heres what i get
    PIN8- Oscilate dbetween 60mV and 220mV
    PIN9- 0.00V (ground)
    PIN14-4.5V
    After grounding PIN14 the relay kicks over and i get..
    PIN8- 5V
    PIN9-5V
    PIN14- Ground
    thanks for the help
    90% Done
    Jun 2002
    Omaha, Nebraska
    Sweet, i got it!!!! Hoora!
    Although it is a mixed celebration. On one hand its functional, everything works, on the other, I'm a dumbass and have been busting my *** over something very stupid. I have pin9 wired to +5V and not standby! jesus, i'm stupid. Thanks for your help.
    90% Done
