Results 1 to 2 of 2
Thread: m2-atx amp on/off
    Nov 2006
    Thornhill eh?
    m2-atx amp on/off
    ok, so i can't get the amp remote to flip my relay and i am anyway i have tried:
    - the left pin to one side of coil and right pin to otherside (and other way round)
    - i have tried left pin to one side of coil other side to ground and right pin to ground
    - also tried right pin to one side of coil and left pin to power and that worked but was not switching, it just flipped it.
    for reference it says left pin is RMT and rite pin GND
    helllpppp
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    It should have worked connected like the first 2 ways you did it. The last way obviously wouldn't switch since it's connected to power all of the time.
    Maybe you're using a relay thats too big.
    Can you try it directly to your amp? Just put the RMT wire on the Remote connection of your amp. Should work also without the need of the GND wire.
    Try measuring the RMT for 12V there when the M2 is powered on. If you don't get 12V there probably is something wrong with your PSU.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
  1. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  2. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
  3. Another M2 ATX Problem
    By mattfl in forum Power Supplies
    Last Post: 02-23-2006, 05:47 PM
  4. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 06:40 PM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
