Results 1 to 8 of 8
Thread: Intel D201GLY2 with a M1-ATX?
    May 2007
    Help!
    I am using a mini-ITX Via C3 mobo with a M1 ATX PSU
    Now with the new Intel D201GLY2 available for cheap, I am getting tempted to replace the board
    However, the M1 ATX only has a 20 pins power supply cable (and not the 4 pin CPU power cable)
    Can i use the M1 ATX to power the D201GLY2 using a molex to 4 pin converter or something similar?
    any suggestions?
    Elsewhere
    There are 20-to-24 pin adapters for ATX PSUs available.
    I'd be more concerned about the ability of the M1ATX to provide the power necessary for that board.
    How about the Wiki?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Here are some links that have a bit of information about powering the D201GLY2
    http://www.silentpcreview.com/article780-page3.html
    http://resources.mini-box.com/online...nsumption.html
    TruckinMP3
    Read the FAQ!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    it worked fine with my non-branded 60watt psu that came with my case... i think the m1 will handle it.
    Live mp3Car Facebook Chat
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    I honestly tought the M1 should have been able to power this board until I came across this:
    NOTE: Do not use M1-ATX as the D201GLY draws V(core) power from the 12V rail, therefore the M1-ATX might not work well despite the fact that it is a 90watt PSU.
    I got it from this website.
    So you probably gonna need a bigger PSU. As DarquePervert said. Many 20 to 24 pin adapters are available to use then.
    EDIT: Wile I was googling, TruckinMP3 seem to have beaten me to it...
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
    Jun 2002
    Colorado
    Quote Originally Posted by Bimmerstyle View Post
    SNIP
    No worries, your info indicating to not use that combination seems more clear.
    I will need to find the 12volt rail specs on my PS to determine if i need to upgrade before my new board goes in.
    TruckinMP3
    Read the FAQ!
    May 2007
    The M1-ATX specs says 2A on the 12V rail which equates to a peak available 24W on the 12V rail
    GIven the fact that the entire system draws around 20-30W, shouldn't the M1-ATX 12V rail be able to power the CPU?
    May 2007
    it powers them just fine, I've got an M1-ATX powering mine, most of the other things I'm running are CF Flash adapter + USB 2.5" HDD and cdrom are 5v, so you'll be fine, just solder a 4-pin connector to one of the floppy connectors
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  3. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 08:31 AM
