20 Watts
Are there any other differences between the M2-ATX and the M2-ATX-HV, besides the wider input voltage range? It would appear that the HV is a better power supply, but if the HV is a better power supply it seems odd to me that it would be less expensive. Maybe I am wrong. Thanks for the info guys/gals!
They are both listed as being 160W on the mp3car store...
So it appears the input voltage range is the only difference. Thanks!
If you goto http://www.mini-box.com/s.nl;jsessio...=8&category=13
you can see the specs.
M2-ATX
NEW! Smart Car PC Power Supply
- 160 watts output
- Ideal car Power supply for operating Core 2 duo, Celeron, AMD systems
- ATX, 6-24V wide input range
- Intelligent shutdown controller
- ON/OFF motherboard control
- Survives vehicle engine cranks
- Battery deep discharge prevention
- High efficiency, 160 watts output
- "Anti-Thump" Amplifier remote control - 15A automotive fuse (mini-blade)
- VIA, P4 and AMD CPU support
- manufactured by mini-box.com
- ROHS compliant version
M2-ATX-HV
- 140 watts output
- ATX, 6-32V wide input range
- High efficiency, 140 watts output
- VIA, Core 2 duo and AMD CPU support
