Results 1 to 10 of 15
Thread: DSATX randomly shuts down with Brainstem hooked to serial port
    Jul 2006
    Hey guys, I have a DSATX and I am having some issues with it. I got it all plugged in last night in full normal mode (as a sdc and everything). It seems to work great for about the first hour or so I had it on. Then I decided to use the brainstem.
    The Brainstem was already plugged into the DSATX (before powering up) using a 4-pin extension jumper I made. The red led on the brainstem was on and everything seemed happy. I plugged in a straight-through serial cable from the brainstem to the PC and the orange led on the brainstem came on. So far so good! I opened up hyperterminal and just opened the connection when the DSATX just shut down. No warnings, no blinking leds. It just dumped. I had to kill the VIN line and shut off the ACC line before it would come back up and when it did it did not give me any blinking leds. It booted up ok with the serial cable attached. Then even before I could get hyperterminal opened up, it shut down again. No blinking leds this time either.
    I disconnected the serial cable from the brainstem (but the brainstem was still connected to the DSATX and restarted the system. Everything seemed to be ok. I check the serial cable for shorts or wrong pin-out, but everything seemed to be fine there as well. I plugged the serial cable back in and was able to monitor the datastream and nothing looked out of place. Voltages were ok, temp was around 36c. It was in RUN mode. I did manage to reset all values to default before it freaked out and shut down on me again.
    What could be causing this?
    Jul 2006
    Bump for the crazy time warp...
    Apr 2001
    Portland OR
    Quote Originally Posted by LYHTSPD View Post
    Try using a ground lead and grounding the serial port cable shield to the main ground pin of the DSATX and see if that helps..
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Jul 2006
    Quote Originally Posted by zootjeff View Post
    Thanks Jeff, I will give that a shot tonight.
    Jul 2006
    I tried hooking up the cable shield to the GND connection. I got much of the same result. It did actually give me a 4-blink led error code though, which I think is for over/under temp right? That does not seem right.
    Without the serial cable plugged in, it ran stable for over 2 days straight.
    Jul 2006
    Anyone?
    MarcelP's Avatar
    Nov 2007
    Germany
    does it function not yet or is now solved the problem?
    My Project: German/English
    Jul 2006
    Oh man, I almost forgot about this thread! lol
    I had made a short extension cable from the header pins to a 9 pin dsub to the exterior of the case. Well, this seems to have been the problem. I even shielded the cable and still no luck.
    I ditched the extension, de-soldered the dsub from the Brainstem and hard-wired the serial cable to the board. Everything works fine now.
    MarcelP's Avatar
    Nov 2007
    Germany
    I have now the same problem. Can you show pictures of it? Because I white not which I with Ground to connect is.
    MarcelP's Avatar
    Nov 2007
    Germany
    Here a Picture: the metallic plug of the Brainstem connect with...?
    (All 9 pins are isolated from the plug.)
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. DSATX Showing Under/Over temp at ~75F
    By cherrybomb in forum Power Supplies
    Last Post: 09-13-2007, 03:43 PM
  3. Replies: 10
    Last Post: 06-19-2007, 04:53 PM
  4. DSATX serial diagnostics spits out garbage
    By zenfe in forum Power Supplies
    Last Post: 11-14-2006, 03:21 PM
  5. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
