I'm using the Opus DCX6-320 and have been
very satisfied with it. Just to give you a rundown on what it can
power from my experience, read the list below:
I have it connected to an Shuttle FT20 motherboard with three thermaltake 80mm fans while running a 2.2Ghz dual core socket 939 processor, 2x2GB of system ram, a dedicated PCI-Express GPU card - the BFG Nvidia GeForce 8500GT 1GB DDR2,
Sound Blaster X-Fi Professional
series add-in sound card with 64MB of XRAM.
For the hard drives, I have two 3.5", WD150AFD 10,000 rpm Raptors in RAID0 (the pair have since been replaced by a 300GB, 10,000 RPM VelociRaptor, and a 7,200 RPM, 1.5 Terabyte Seagate Barracuda). Also connected to the power supply is a full sized 24X
Samsung lightscribe multi-format dvd burner, a Dynex 30 in 1 multi-format USB memory card reader, three four-port USB hubs daisy chained, totaling twelve peripherals that are always on. Drive letters B, C, D, E, F, G, H, I, J, K, L, M, O, P, are in use by
Windows Vista.
If you thought like I did, that the PSU was already at maximum overload, get this- the DCX6-320 is also providing a constant 12Volt regulated power output to my seventeen inch widescreen flat panel LCD display!
Rest assured, tried, tested, and approved...this is the only power supply you would realistically ever need for automotive purposes.
Bang for the buck, I'll admit the Opus DC6-320 is a tad bit on the high side, nevertheless, it has been in use for over a year now and has outperformed the actual PSU that came with the Shuttle ST20G5 gaming PC box, and also the Antec450 aftermarket PSU.
I ordered mine online, through
www.opussolutions.com. The package arrived on time as promised, double boxed with popcorn foam. Included were the
wiring harness (2 ea), external mount LED with connector, various jumpers, and installation instructions.
The DCX6-320 is assembled with superior craftsmanship using some of the finest electronic components. I give it a 10 out of 10 kick*** product rating
~DMand
