This thread will serve to post all relative information for the Opus 320 watt Intelligent DC-DC PSU.
This thread is not to be used for troubleshooting, but rather for FAQ type responses.
Printable View
For PC to work properly with remote power on and hibernate, the BIOS has to support ACPI 2.0 to work with Opus 320W.
The opus 320 does not fit in varoom case
it's just a circuit board, how can it NOT fit... anywhere? :)
Little love for the Opus 320. How bout someone with some knowledge and the PSU could explain what the 10 wires on the input harness are for?
When in doubt, reading the product manual is always a safe bet: http://store.mp3car.com/ProductDetai...4&Show=ExtInfo
Accordingly, on page 3 of the manual
In order of the pins:
- GND
- GND
- GND
- ON/OFF
- 12V out
- +BATT
- +BATT
- +BATT
- RMT-1
- RMT-2
Yea I printed out the whole manual but I wouldent mind a short explination of where the wires go?
hey, isn't there a dedicated place for Noobz, Newbies and beginners ?
Well uh, I don't want to look harsh, but if you can't figure how to connect these wires (with pretty explicit names), then you're slightly unprepared to mess with carputers
GND = Ground (negative pole of the battery which means the body of your car
+ BATT = positive pole of the battery
On/Off = probably is to be connect to a switch with other wire connected to ground
12vout = stabilized 12v output
RMT1/2 = remote 1/2 to be connected to amp and other systems
Pfff damn noobz :D
Just dont wanna fry anything I knew where everything went except the 12v wire didnt notice it was output. Thanks
im an electrical engineer n i had a miss understanding there myself too , you just wanted to burn on an upid question , but n another note that rmt=remote , tanks , that cleared my question , n made up my mind , this is not the one i need cause im not opening the dash in my new truck.....:yield::peep:
