Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: DSATX 220 watt Automotive Power Supply
  1. #11
    Feb 2011
    Quote Originally Posted by zootjeff View Post
    We can fix this for you if you like, good point. Want me to send you a firmware update to extend it? What is a good upper limit?
    -Jeff
    Thank you, sounds good.
    I havent bought the PSU yet, so no need for that yet. Still waiting for my car to return from the workshop.
    For me personally the upper limit would be something like 192 hours and the lower limit 1 hour. Is that possible?
    Is there a case available for the DSATX?
  2. #12
    Feb 2011
    So has anyone found a pre-fabricated enclosure for the DSATX?
    There is no way I can fit it into my PC case, so I have to make it external.
    Or did anyone make a case by themselves and maybe still have the plans for it?
    Thanks in advance, guys.
  3. #13
    Oct 2012
    Hi Jeff,
    Is the DSATX 220-Watt DC-DC ATX PSU supplied with a 24 pins ATX connector, as now all MB's have 24 pins connector and ATX CPU 12V power cable has 8 pins?
  4. #14
    Oct 2012
    One more question - is your DSATX 220-Watt DC-DC ATX PSU working with S27-USB-SERIAL Acroname USB Serial Adapter as S19-USB-SERIAL indicated in the user manual is no more available? Thanks
  5. #15
    Feb 2011
    Quote Originally Posted by esilviu View Post
    Hi Jeff,
    Its only 20 pin and 4 pin. But thats not really a problem. It would only play a role if you were going to use a CPU that draws a lot of power or overclock a lot. The extra 8 pins are only there to handle the added current (heat) for high power draw systems. So if the DSATX' output amperage is enough for your system, there should not be an issue. I have never had issues with with several mainboard and CPU combinations that had 24 and 8 pin sockets, with only 20 pin and 4 pin connectors in em.
    In theory, if you put out too much current over the 20 and 4 pin connectors, they can overheat and catch on fire in the worst scenario. Since that actually happened quite a lot since there are many people who overclock with stuff like dry ice and up the clock to 8+ GHz and high end AMD CPUs draw a lot of power even without overclocking, 8 more pins were added, to be on the safe side.
    So unless youre planning for such a system, you can rest your mind on this matter. And even if that isnt enough of an explanation for you, you can simply put your PC to maximum load and measure the temperature of the connectors/cables.
  6. #16
    Oct 2012
    Thanks very much for the info.
    Do you know if the -5V does matter or no , DSATX doesn't have -5V , as my MB pin diagram shows a -5V line, see pics bellow
    my MB
    Name:  MB ATX pin diagrams.JPG
    DSATX
    Name:  220W DSATX pin diagrams.JPG
  7. #17
    Feb 2011
    -5V is obsolete since ATX 2.0. No worries.
  8. #18
    Oct 2012
    This is a new Z87 Gigabyte MB, why they are still indicating -5V , I checked with an Asus Z87 too, and is also showing this -5V line , it's strange as this is not necessary anymore!!
    Do you have any experience with this PSU, any noise (rfi) induced in the audio system?
    Is this the best between the OPUS, M4-ATX and the others on the market?
    I'm about to buying one and want to be sure I get the best.
    Thanks very much for your answers
  9. #19
    Feb 2011
    Read up on it on Google about ATX specifications. -5V isnt needed anymore and many manufacturers dont connect it anymore to anything and some even leave out the cable completely.
    I had several M3-ATX before, which caused a lot of audible interference in my optical-out only audio system and even caused my monitor to flicker. With the DSATX that is gone. Also other people who use the DSATX all said to me that it is a very clean PSU in terms of RFI.
  10. #20
    Oct 2012
    Thanks a lot!
  1. FS: DSATX 220 Watt Power Supply
    By Norrin302 in forum Classified Archive
    Last Post: 06-13-2006, 08:36 AM
  2. FS: M1-ATX 90 Watt - Smart Automotive Power Supply
    By csnv in forum Classified Archive
    Last Post: 09-30-2005, 01:46 PM
  3. New Mpegbox Power Supply
    By zootjeff in forum Power Supplies
    Last Post: 09-20-2005, 01:32 PM
  4. FS: OPUS 150 watt DC-DC power Supply
    By wh0k in forum Classified Archive
    Last Post: 03-25-2005, 05:56 PM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
