Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: DSATX 220 watt Automotive Power Supply
  1. #31
    Feb 2011
    Well, I changed the batteries today and it would still turn off the PC while cranking. Then I changed random settings on the DSATX and it turned out the problem was gone when I doubled the default value (50) of ACCTIMEVAL to 100. Not quite sure what that setting does, but it works.
    The batteries were shot in any case, so no loss.
  2. #32
    Feb 2011
    Alright, so I played with the settings of the DSATX a bit more and I am quite confused.
    The ACCTIMEVAL not only seems to affect the time it allows to crank the engine, but also the delay before the DSATX will will start the PC (and I think even shut it down).
    So if I put in a value of 150, it will give me time to crank the engine 1.5 secs before it will turn off my PC, but it will also cause a delay of 1.5 secs before the PC is started after I turn on the ignition, and also after I turn off the ignition before the DSATX turns off the PC.
    Is there any way to separately adjust those times?
    I tried the other options like TURNONDELAY, TIMER1EE or VOLTSTHYST, but those dont seem to override what ACCTIMEVAL does, nor do they help if I leave ACCTIMEVAL on the default value.
  3. #33
    Feb 2011
    Well, looks like it was my car all along. When cranking the engine it turns off all ACC sources. I took the ACC signal for the DSATX from a line that also turns off, so of course the DSATX will then send a pulse to turn off the PC when ACC goes away.
    Anyway, I thought the DSATX registers that and will prevent it?
  4. #34
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    Quote Originally Posted by Gullimonster View Post
    It will register that and send the pulse to the motherboard with a delay (which can be set with on the dsatx with P1 (0-20 minutes). Your wiring is correct. You should turn P1 more to set more delay for the turn of pulse.
  5. #35
    Feb 2011
    Quote Originally Posted by Nomader View Post
    That delay also affects the normal shutdown, but I want it to shut down quickly when I take the key out.
  6. #36
    Feb 2011
    So does anyone have a suggestion how I can keep the ignition signal active while cranking without affecting the normal cycle? Voltage is completely shut off when cranking. I expected the DSATX to act like the Mx-ATX PSUs, which will keep running even when the ignition signal shuts off during cranking.
  1. FS: DSATX 220 Watt Power Supply
    By Norrin302 in forum Classified Archive
    Last Post: 06-13-2006, 08:36 AM
  2. FS: M1-ATX 90 Watt - Smart Automotive Power Supply
    By csnv in forum Classified Archive
    Last Post: 09-30-2005, 01:46 PM
  3. New Mpegbox Power Supply
    By zootjeff in forum Power Supplies
    Last Post: 09-20-2005, 01:32 PM
  4. FS: OPUS 150 watt DC-DC power Supply
    By wh0k in forum Classified Archive
    Last Post: 03-25-2005, 05:56 PM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
