Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #91
    May 2009
    Are there any PSU's that have a better track record with RFI?
    I heard they pretty much all suck...
  2. #92
    Jul 2007
    IL
    Well, I was the one that brought up this RFI business. turns out the PSU is likely not the cause of my RFI.
    I pulled my vehicle into the garage and plugged in an AC power supply to the wall and the interference still existed.
    I get AM and AM HD great though!
    FM still sucks. Considering I'm running an older motherboard with a P4, perhaps a newer generation of technology will help.
    The current case is steel. http://www.newegg.com/Product/Produc...82E16811154062
    There is a vent in the top. Maybe that's letting the RFI 'bleed' through.
    This is in an Explorer. Computer is in the back. The radio is under the back seat.
    @joshuo. I heard that some people like the OPUS better. I was going to go down that road until I had the same results with an AC PSU.
  3. #93
    May 2009
    Quote Originally Posted by peterfnet View Post
    I don't think it would. It should still act like a cage of Faraday. S mesh is fine as long as it is grounded as well. (unless it has a rubber gasket sealing it from the box, i don't see why it would give you issues.
  4. #94
    Sep 2008
    Quote Originally Posted by Virac View Post
    Im having a few problems with my M2-ATX.
    1. When i turn off my car the power pulses and the computer does a hard restart, then 5 secs later will shut down, I have the jumper in position 1. I have tried swapping the IGN and POW lines but I know that is not the issues cause when i turn off the car the computer powers off instantly and when it comes back on i get a warning that the system didn't shutdown properly.
    I'm having the same issue - when I turn the ignition off, there seems to be some kind of a power pulse, the computer simply powers off without proper shutdown, though the monitor stays on (or maybe it just turns back on right away). In 5 seconds everything turns off.
    Update: Finnally got a 13.8V AC/DC power supply and the M2 behaves properly. For other reason main power must be fluctuating.
    So it wasn't enough voltage? Could it be the case for me too?
    D945GCLF2, Atom 330, M2-ATX, EBY-701, Pharos GPS-500... - Assembled & Installed!
  5. #95
    Sep 2008
    Quote Originally Posted by alpax View Post
    Just wanted to share my experience. I had this problem, tried to replace the PSU - no change, the new one behaved the same way. I did some more experiments and finally could make it work as it should!
    I just used the power filter, which came with Lilliput: connected the ignition through that filter, and it solved the problem! Now it works as it should.
  6. #96
    Dec 2008
    yes, i can also confirm that if your batt+ is hooked to a power source that fluctuates when you turn the REM lead off- the m2 will shut off completely for a split second and then resume normal shutdown pulse.
    its not really a fault with the m2 though. you must have the batt+ of the m2 powered with a steady 12v at least even when shutting the ignition off (this fluctuation can happen on more circuits then you would think) so if its happening its really an install problem.
    ludikris, im guessing that power filter has capacitors in it, thats why its working for you. im sure any decent sized cap across the batt+ and batt- of the m2 would help in those situations.
  7. #97
    Sep 2008
    Quote Originally Posted by trader007 View Post
    Hmm... I thought the whole idea of this PSU was to receive unregulated input, which could fluctuate from 6 to 24V, and output steady 12V, 5V, and 3.3V.
    If it cannot handle this, I believe it's definitely a design flaw.
    BTW, in my case the power from the battery+ is pretty steady - I double-checked that.
  8. #98
    Mar 2006
    Colorado, but Canadian!
    It does not need to be regulated 12v, it can be anything. It can survive down to 6 or 7 I think when cranking. It works just fine on mine.
    I think what he is saying (although I have never experienced this to be true) is anything between 12v and charging voltage is ok when shutting down, lower and it doesnt?
    On mine though I can do whatever and it works. I can turn on the HID lighting which draws an ENORMOUS current from the battery fast with the car off and the CarPC in its 30s before shutoff, and the PC will keep on truckin'. I can start the car when the CarPC is in its 30s before shutoff which definately dips it to 6 or 7 and it will keep working just fine.
    Only difference is I have the regular M2, not the M2-HV. Also I have a real M2. If you bought it off of ebay for $30 to $50 then you have a chinese knockoff copy that has known problems. Lots of problems. You get what you pay for. Expect $70 to $90 new.
    1.9in x 2.9in -- 47mm x 73mm
  9. #99
    Sep 2008
    Quote Originally Posted by 2k1Toaster View Post
    Yes - that's how it's supposed to be. In my case any disconnection of the ignition line - when I was turning the key to OFF or starting the engine - caused some impulse from the PSU, which instantly powered off my computer without shutting the OS down, and eventually it died so could not boot up. My fix with adding a filter on the ignition line made it work as it should. Now I can start the engine with the computer running, can turn the ignition off, then back on - it's working. Only after 5s delay (I use P1 mode) it starts shutting down.
    Mine is the regular M2 as well, and it seems to be real - I bought it for ~$75 from mo-co-so.com.
  10. #100
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 11:04 AM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 02:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 06:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 06:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 10:03 AM
