Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #121
    FLAC WuNgUn's Avatar
    Sep 2007
    Why are you double posting your problems?
    http://www.mp3car.com/vbulletin/powe...ion-off-3.html
  2. #122
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Because they are in threads that talk about both.. I didn't start NEW threads, I posted in EXISTING threads that mentioned the problem in each..
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #123
    Oct 2009
    NorCAL
    Will this m2-atx be able to support an LCD monitor with 12v, 15watts requirements? After looking at the the technical specs in the store page, I see that at the bottom of the 2nd chart it states that off of the 12v rail, its MAX and Peak current are 8watts and 9watts respectively. Therefore I assume that this is not enough to handle an LCD with 15watts requirement. Can anyone advise me if I'm wrong?
    #Edit/Correction: I'm sorry I JUST realized that the PSU current output is 8amps and 9amps, not watts(which is power), duh... But My question of compatibility still stands. Is there enough power output for the 12v 15watt lcd?
  4. #124
    Dec 2006
    I found an issue with my m2atx. I dont know the actual issue, but when i boot up with it in the car, the keyboard works on the post diagnostic screen and i can get into bios after that, bios does not respond to keystrokes. Same if i try to boot from cd once past post and i am prompted to press any key to boot from cd no response on usb or ps2 keyboards. Also if i let it boot all the way to windows os only 2 usb ports work, others have no power. I pulled it out, connected my car pc to a normal desktop powersupply and all is well all usb ports work just fine.(good news at least)
  5. #125
    Dec 2008
    Quote Originally Posted by mchuang View Post
    weird problem...but from what you describe, apparently the power supply isnt supplying 5v power? if you can check it with a multimeter that might tell you a 5v line is dead... sounds goofy though, i didnt think the motherboard would boot without proper power going into it.
  6. #126
    Dec 2006
    Quote Originally Posted by trader007 View Post
    It would still boot just fine and function normal, just i lose usb ports and during post i lose keyboard functionality. Originally thought it was cmos battery so reset cmos and replaced battery, but same results.
  7. #127
    Mar 2006
    Colorado, but Canadian!
    That more than likely is you overloading the 5v rail... Or trying to power USB devices through unpowered hubs.
    1.9in x 2.9in -- 47mm x 73mm
  8. #128
    Oct 2003
    Poland, OH
    Quote Originally Posted by tbird2340 View Post
    I seen one member use the liliput egg / filter before.. Could I try that? If so, how would I wire that up?
    Issue fixed.. What I did was temporarily install the egg inline with the ignition wire and it worked..
    So I then went to wire it permanently but before I did that I worked on it a little more and it started working correctly, without the filter!
    It's like having the filter in there for a few boots fixed it.. Weird..
    Anyhow, it's working normally now, without the filter.
  9. #129
    Dec 2006
    Quote Originally Posted by 2k1Toaster View Post
    I will go with your first answer and hope your right. Which sounds possible. Do you know of any hubs i can power without using an extra usb port on my motherboard like from battery power?
  10. #130
    Nov 2009
    I am preparing 2 carputer with M2-ATX and asus at3n7a-i atom330.
    To do the tests use a PC 300W ATX power supply.
    When ignition is on the motherboard is powered in a strange way, in the sense that the MB power LED flashes (as if in sleep) and nothing on the the PC work (usb radio leds and MB power led blink). After a variable time (1 minute, 2 minutes, 10 minutes, never) the PC turns on (but not always) and everything runs smoothly, including soft off by disconnecting the ignition. In practice I have to start using P0 (like a normal PC power supply) and then change to P1 to have a soft off when i turn off ignition (simulated with a switvh on the 12v line in).
    I have a twin pair of components and both of them work in the same way, changing the polarity of j8 too!.
    May be incompatibility between m2-atx and asus ion itx, wrong wire connection or incorrect bios settings?
    Sorry for my spaghetti english.
    Thank you.
    Ciao.
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 11:04 AM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 02:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 06:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 06:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 10:03 AM
