Page 14 of 14 FirstFirst ... 4567891011121314
Results 131 to 138 of 138
Thread: M2-ATX(-HV) 160 watt Intelligent DC-DC PSU
  1. #131
    Jan 2010
    Similar problems, other thoughts?
    I have the HV version and I've noticed exactly the same thing as others have posted, the PSU works fine on bench and during boot in car, and does HARD off when the ignition is turned off.
    I have a switch hooked up to the ignition line for the computer which is either "on" (+12v) or "ignition" (whatever state the ignition is in) with a center "off" position.
    I've noticed that if I flip the switch to off before turning the ignition off, it works correctly. So the problem is something to do with the +12v line going from ~14v to ~12v (charging system / alternator turning off) AND ignition going from logic high (higher then ~10v) to logic low (0v) at the *exact* same time. I say exact because i've tried to flip the switch and ignition at the same time, and I've gotten close so I think that *any* amount of time delay from logic low to a sudden ~2v drop on the +line
    I was more wondering if anyone has tried any other PSU's the M1, M3, or M4. With the M4 does anyone know if it controls power state through the USB connection (sweet) or is that just a fancy program for showing me the output voltage of the PSU (fairly dumb)?
  2. #132
    Low Bitrate Belo's Avatar
    Jan 2010
    Buffalo, NY
    Does anyone have a picture with the m2 atx all hooked up to a board? I want to make sure I have all my ducks in a row before I power her on.
    Also, do you guys use the case led power indicator lights hooked up to your mobo, or do you have your power led's connected to the m2?
    btw the instructions for this product are **** poor.
    09 Pontiac G8GT [decently modded]
    former carputer owner, given up for iphone
  3. #133
    Mar 2010
    Quote Originally Posted by Belo View Post
    yea i too would like to see this...
    i still dont get how to hook up my power switch, does it matter, or is it polarized, and if so, what is what. same for J6... what is +?
  4. #134
    Jan 2010
    Buffalo, NY
    Quote Originally Posted by tongputer View Post
    i have the pic i took myself now I'll post it later
  5. #135
    Mar 2010
    M2 Power?
    So, I took the M2 right out of it's package, hooked the 12V, ignition, and gnd to a DC power supply set to 12V. The board powers up and switches when i ground and energize the ign wire, but when we plugged the ATX connector into our cpu, the cpu nothing happens. The board draws 400mA just by itself it seems. We probed the power pins on for the HD and there is no voltage. Is there anything special I need to do to get an output voltage? My M2 came with zero documentation, but from what I hear the information contained in the documentation is pretty sparse.
    Any help would be greatly appreciated.
    Thanks!
  6. #136
    Jan 2010
    Buffalo, NY
    Quote Originally Posted by bbenoy View Post
    Thanks!
    http://resources.mini-box.com/online...anual-engl.pdf
  7. #137
    Jan 2011
    Does anyone know if the M2ATX PSU harness/cables can be purchased separately from the PSU itself? I picked up an M2ATX that had seen better days, with several of the capacitors bulging and ready to die at any moment. I recapped the entire board with top shelf Panasonic capacitors, but now can't seem to find a ready source to buy the harness to connect it to my Zotax mini-ITX MoBo.
    Will I have to assemble one from parts or can one be bought outright? I really don't want to have to spend any more time monkeying with this...
    Thanks.
  8. #138
    Nov 2004
    DC
    Im thinking about locating my new car pc where my old head unit is to save on cable extensions and such. Would reusing the old 12v and 5v lines that were going to the head unit be ok with this power supply? Or should I run new lines? Can't I just steal power from the switched 5v red wire as my ignition wire? I do plan on running a new ground wire to the chassis regardless. Thanks!
  1. Where can I buy an ATX DC to DC PSU online?
    By Ritalin Kid in forum Classified Archive
    Last Post: 07-19-2002, 12:04 PM
  2. 250 Watt ATX DC-DC PSU
    By mhermann in forum Power Supplies
    Last Post: 01-28-2002, 03:34 PM
  3. dc dc psu for a micro atx case
    By y0manda in forum Power Supplies
    Last Post: 12-23-2001, 07:04 PM
  4. 85 dollar DC to DC ATX PSU
    By citrus3000psi in forum Power Supplies
    Last Post: 07-21-2001, 07:56 PM
  5. Has anyone tried modifying a 110v atx PSU to 12v DC?
    By HappyPuppy in forum General Hardware Discussion
    Last Post: 11-12-2000, 11:03 AM
